problems with new tune..
Old 05-05-2006, 01:38 PM
luckyou03's Avatar
Default problems with new tune..
ok here's the history:
1st setup:
hotcam, shorty headers, catback, stock cat, stock tb
- got it tuned by pcmforless, ran great!
2nd upgrade:
still hotcam, 1.6rr, longtubes, no cats, true duals, 52mm tb
- ran the old tune(above), runs strong but pops/backfires when WOT. Drives normal except WOT.
Just got my new tune for the new mods and i can't even drive the car down the road.. It's been double checked by pcmforless, and emailed to me twice. i've loaded it 3 times with no driveable success. it dies, shutters, shakes and has no power.
I'm running the old tune right now to be able to drive the car. PCMforless said i have something mechanically wrong?
Here is a vid with the new tune: http://lt1engine.com/problem.mpg
I've replaced virtually every singe sensor with about 3-4 months run time on them. (02's,knock,water temp,pcv,new plugs,wires,opti). I am running the original tps, maf, iac, iat, map and evap.
btw i'm not throwing any engine service codes.
Old 05-05-2006, 01:54 PM
dhdenney's Avatar
You've added roller rockers to the mix. Do you have a way to monitor the amount of retard you're experiencing?
Old 05-05-2006, 02:00 PM
luckyou03's Avatar
i can hookup a laptop with pcmcomm.exe http://carputing.tripod.com/9495LT1Edit.htm . but i dont have any type of scan tool other than that.
Old 05-05-2006, 03:02 PM
Honda Hunter's Avatar
freescan. How can you have a mechanical problem when the car runs fine on the old tune?
Old 05-05-2006, 03:03 PM
blkchevyz's Avatar
if you want i can take a look at both your old and your new tune.
shoot me a pm and i'll send you my email address.
Old 05-05-2006, 03:05 PM
luckyou03's Avatar
thats what i dont get!!!
Old 05-05-2006, 03:06 PM
Are you posotive it runs fine with the old tune? Mabey he sent you the wrong file?
Old 05-05-2006, 03:07 PM
slowmofo's Avatar
sound like its just rich with the old tune, and the new tune is fubared
blkchevyz's Avatar
what valve springs are you running?
Old 05-05-2006, 03:09 PM
luckyou03's Avatar
well i emailed him and he sent me an email back saying he checked it and i have some type of mechanical problem. i sent an email back saying i'm driving the car perfectly fine except for wot popping with the old tune. I haven't recieved a response.
I'm 100% sure the old tune works, because it's my daily driver and thats the tune in the car right now. I got him to email it twice, just in case he sent the wrong one, and i got the same results.
Old 05-05-2006, 03:12 PM
luckyou03's Avatar
lt4 springs with 1.6rr on lt4 hotcam, car starts to go on new tune, but then falls on it's face and dies, shakes.
Old 05-05-2006, 03:15 PM
blkchevyz's Avatar
i was thinking you could be floating the valve making it pop and bang in wot.
i'll look at the tune when i get home
Old 05-05-2006, 03:16 PM
luckyou03's Avatar
i just figured i was popping because of the longtubes and no cats
Old 05-05-2006, 03:17 PM
Couldnt hurt to rule it out.
Old 05-05-2006, 03:18 PM
blkchevyz's Avatar
the long tubes and no cats would make it pop when you let off... but it shouldnt be popping under throttle.
Old 05-05-2006, 03:20 PM
luckyou03's Avatar
what causes valve float, do i need to go check my springs? yes as soon as i get it on it, it goes Bang Bang then takes off.
Old 05-05-2006, 03:53 PM
street demon2k3's Avatar
dont know if this matters but have you replaced your opti, or how many miles do you have on it? i had the same problem when i did the 230/236 cam and it ran fine with the tuning till it started to miss and pop when i got on it. replaced just about every ignition related component then found out my opti was shot? mine would run fine under light loads but when i would go WOT it would miss and pop but it would still keep pulling till i let off. finally after a few days it just started missing at all rpm's. dont really know if it helps but its worth a try.
Old 05-05-2006, 03:57 PM
luckyou03's Avatar
i installed this opti last august. if my opti is bad, i'm gonna burn it. we'll see see what blkchevyz says about to tune before i go replacing stuff.
Old 05-05-2006, 08:13 PM
luckyou03's Avatar
update! took the pc out in the garage ran the pcmcomm.exe scan tool. here are the results:
car off
Start up
car running 1 (open loop)
car running 2 (open loop)
car running 3 (open loop)
car running 4 (closed loop)
car off
as the car warmed up the right 02 stayed consistantly lower.
Old 05-05-2006, 08:33 PM
DeltaT's Avatar
Almost sounds like you are hitting an incorrectly set rev limiter... The rev limiter should be set for something like 200-300 over the point your cam really runs out of steam, which on the hot cam would be a setting like around 6300-6400.
Does it die as soon as you open the throttle all the way or do the revs have to climb to a certain point then it dies? That can be a hard point to find in a low gear - try 3rd at a moderately low speed and see if it is TPS dependent or RPM dependent.
Jim
Quick Reply: problems with new tune..
