Which spark plugs to use???
Old 05-06-2006, 09:14 PM
DomesticLS1's Avatar
Lightbulb Which spark plugs to use???
Hi im about to do a plug change on my 99 trans am and I was wondering which plugs are the best to use. Motor is stock, I was thinking to use the bosch platinum 2's...Which do yall prefer?
Old 05-07-2006, 12:51 AM
staringback05's Avatar
dont do the boschs, go with the ngk tr55s or the ac delco iriduims....the tr55s are about 12 bucks total and the ac delcos are a bit more but are a good plug....dont go with anyother ngks really unless ur spraying or heavily modded
Old 05-07-2006, 12:52 AM
o yea and now would be a good time to change wires to, go with a thick wire bc the freakin headers get in the way and burn the lil guys
Old 05-07-2006, 12:40 PM
ok thanks...I just ordered the msd 8.5's off of ebay...They were 200.00 at autozone and I just bought mine new for 62.00
Old 05-07-2006, 01:06 PM
200 bucks?!.....they should have been like 80 something...is your autozone in like russia?
Old 05-08-2006, 08:35 AM
4ced's Avatar
Originally Posted by DomesticLS1
They were 200.00 at autozone and I just...
please specify you want the wires for an 8 cylinder engine not a 24 cylinder
no serioulsy they shouldnt cost more than 80 or 90 bucks at the most perhaps you were looking at something else?
Old 05-08-2006, 08:53 AM
savethelinoleum's Avatar
I prefer the delco's as most people seem to get shorter intervals out of the NGKs
Old 05-08-2006, 09:01 AM
Orange Terror's Avatar
I just put NGK TR-55's in mine this weekend with the MSD 8.5mm wires. It rocks, noticable difference indeed.
FYI, you can order the MSD wires from Summit (www.summitracing.com) that's what I did. $58 and free shipping.
Old 05-08-2006, 09:31 AM
Z28LS1camaroguy's Avatar
NGK TR55 Iridiums are really good plugs, i got mine from a board memeber on here for like 35 bucks shipped for all 8.
Old 05-08-2006, 11:04 AM
BigBas83's Avatar
is there any reason NOT to use Bosch platinum plugs? or is cost the only factor?
Old 05-08-2006, 11:45 AM
I just put the bosch platinum 2's in my car and I can tell a big difference. Runs alot more crisp and smoother. So far I like
Old 05-08-2006, 12:14 PM
ive heard more bad things about them then good, i know of one instance in a 383 where one failed, caused a dead cylinder. friend said he thought it was the core inside that broke down, when he took it out there was a powder coming out of it. ac delcos are what gm says run in the car, and the iriduims are a good plug the normal ngks 55s are good, but the ngk iriduims are a colder plug and are good for sprayed engines
Old 07-17-2006, 02:23 AM
Joey7489's Avatar
T.T.T. I have a question,
I just bought Bosch plugs, just the normal ones not the 2's, 3's or 4's. I bought them because the store ran out of NGK and I had my headers off so the timing was right. I spent like $20 or something on all 8 plugs. Question is, should I keep these? Or get NGK TR55's or NGK Tr6's?
Old 07-19-2006, 09:58 AM
dirtyblackhoe's Avatar
what heat range and gap should you run? I plan on just going with longtubes, true duals, and intake. nothing other then that.
Old 07-20-2006, 12:43 AM
gnomee's Avatar
If your just putting on intake and long tubes I would recommend the Delcos. They seem to be really good plugs and they are what came in the engine. The only reason to go with another plug IMO is if you are spraying and need a colder plug or want a hotter plug for some crazy reason. The delco plug is plenty of spark for what you are talking about and they will last a long time. I got 110,000 out of my stock delcos and frankly didn't notice much difference when I changed them.
Old 07-20-2006, 01:03 AM
Joey7489's Avatar
Right now Im running stock gap which is I believe .060. I think there are many people who have been running .050 and say there is a huge difference in throttle response. I just bought some NGK TR55's and I am gapping them at .050. I also got MSD 8.5 spark plug wires. Ill post up and let ya know if there really is a difference, but it might be a while, because Im running seafoam in the car right now, and Im waiting 200 miles to change my oil/plugs/wires.
Old 07-27-2006, 02:12 PM
b's90cam's Avatar
Hey whats the difference betwwen 32819 ans 32079. All i can see in $50.
32819
http://store.summitracing.com/partde...5&autoview=sku
32079
They both have the same specs at the bottom of the page.
Old 07-27-2006, 06:35 PM
HeapaShifter's Avatar
The difference is the boot that goes over the spark plug. One has a stock straight boot and the other has a multi-angle boot.
Old 07-28-2006, 01:53 AM
b's90cam's Avatar
worth $40 to $50
Old 07-28-2006, 01:58 AM
98hardtopZ's Avatar
tr55's all the way
