victor jr. users.... need pics of your fuel rails...and some info
I bought my manifold before they offered it with the fuel rail "kit" i have the nasty performance rails and their "kit" but it doesn't have the spacer between the rail block and the manifold, i'm needing to know how long that spacer is, what size it is, and what size thread/pitch the bolt is to bolt it down to the vic. jr. thanks for any info.
oh i definatly need them....gotta feed this beast with something. i guess i could run 2 seperate fuel cells and just have a block that dumps fuel directly into each cylinder....
Carlos Villalon, Jr.
run an aftermarket fuel pressure regulator just like a carb setup....
Carlos, you think i could buy the edelbrock rail "kit" and still get away with using the Nasty rails with the edelbrock kit? and just sell the edelbrock rails or something...
Carlos Villalon
honestly the nasty rails were free so i could actually make some cash on the deal. awesome, you don't happen to know what size the inlet/outlets are on the edelbrock rails do you?
"Aluminum Fuel Rails
CNC machined from aluminum extrusions, these fuel rails have a 9/16" i.d. fuel passage, a flow-through design and 3/8" pipe threads on both ends. All hardware is included. Bracket stands included match with standard injectors (2.650" O-ring spacing) or pico injectors (1.50" O-ring spacing) as indicated."
The part number is #3638. Summit #EDL-3638, list for $69.95, and are in stock.
I would have opted for the Edelbrock rails from the begining, but there was a backorder on the manifold that came with them. At that time, their rail supplier couldn't keep up with the demand. Looks like they have taken care of the supply issue. When I go to larger injectors, I'm going to get the Edelbrock rails.
