Torque arm
Old 05-07-2006, 09:56 PM
dhpewterz's Avatar
Default Torque arm
ok guys i must be real stupid because im not getting this i need a chassis mounted torque arm for my m6 to th400 swap i know i need the crossmember conbersion but where do i find the chassis mounted torque arm i looked at bmr and it looks like the one i need but i see no where on the torque arm where it bolts to the crossmember is it just not shown on the picture on bmrs website it part# ta002 please help.
Old 05-07-2006, 10:10 PM
kpowr82's Avatar
??? a tunnel mounted torque arm has nothing to do with the tranny crossmember. It bolts to the floor where your tunnel brace was before your header install (I had to remove mine). May I suggest a UMI tunnel mounted torque arm? I am extremely happy with mine. Its only hit the floor maybe twice since I've had it and doesn't vibrate nearly as badly as some others have experienced with the BMR and Spohn TAs.
BTW, you're not stupid (you can't be, M6 -> TH400 equals ), we all had to learn about things at one point or another.
Old 05-08-2006, 07:32 AM
UMI Performance's Avatar
Thanks Kpowr82
The nice thing about a tunnel mounted torque arm is no matter what transmission you are using the torque arm will work just fine. Both of the tunnel mounted arms in the links below will work for your swap, it just depends on what exhaust system you are using. If you need any help send me a e-mail or PM.
http://www.umiperformance.com/2202.aspx
http://www.umiperformance.com/2200.aspx
Hope that helps
Ryan
Old 05-08-2006, 07:46 AM
ls1mongrel's Avatar
Go with the UMI its was a great upgrade !
Old 05-08-2006, 07:55 AM
227Hawk's Avatar
You'll find it hard to buy a T/A that looks or performs better then an U.M.I.
Hawk
Old 05-08-2006, 08:13 AM
LS1Tech Premium Sponsor
BMR Suspension's Avatar
The part # of the relocation mount you need is TCC010 if it's a LS1 car and TCC014 if it's an LT1 car. This will mount the TA002 to the car no problem. What is nice about the relocation mount is you can move the nose of the torque arm up and down to control how the power is applied to the tires. If you have any other questions just let me know
Lee Spicher
lee@bmrfabrication.com
(813)986-9302
Old 05-08-2006, 12:17 PM
dhpewterz's Avatar
I am running pacesetter lt with the pacesetter y-pipe into a cutout with the stock muffler just so i could sneak up i people lol but thanks for all the info thats what i needed to know later
Darren
Old 05-08-2006, 01:29 PM
sprayinss's Avatar
i run a jegs tunnel mount ta,i like it to,just another option if needed,hope ya figure it out!
