Turbo Camshaft in 347
Old 05-10-2006, 02:26 PM
67Firebird455's Avatar
Default Turbo Camshaft in 347
Puttin together the new forged motor to run 14.7# and am debating the LS6 cam or the Comp XR265HR-15 which specs can be found here
Operating Range - 1,500 to 6,800
Duration @ .050" - 212º/218º
Advertised Dur - 265º/271º
Lift (int/exh) - .558/.563
Lobe Separation - 115
Grind # LS1 XR265HR-15
Would be real nice to build boost on my rear mount and still get an aggressive sound out of it without drawing too much attention from the PD. Recommendations?
Old 05-10-2006, 03:00 PM
98turbls1's Avatar
first of all you know that 1-bar is just atmospheric pressure itself...I think that you're talking about a 2-bar setup...hahaha...=) I think that the comp cam would sound pretty good...It's not going to be too annoying and it would be a pretty nice cam for boost...If you do it you should post some vid for other guys wanting to decide on a cam selection..
Last edited by 98turbls1; 05-10-2006 at 03:04 PM. Reason: didn't complete statement
Old 05-10-2006, 03:14 PM
Dangit... I'm such a moron some days. =) I'm very curious what the cam would sound like and how it would perform. As I'm going from a hot cam, I'm sure it would be quite an improvement! I may just end up heading that direction and definitely get a recording and post it up for others to hear. It's only the high-lift grind that has THOSE specs, the other one is on a 114lsa, much lower lift and rated to 6k rpm. Slowly but surely, getting it going. Thanks for the correction and opinion.
mahhddgtp's Avatar
But, when he says he's going to run 2-bar.. that means his goal is 29psi. (1bar=14.5psi). But, I think he really meant his goal is 1bar... 14.5psi... 1 bar is atmospheric pressure, but since the motor isn't truly going to read 14.5psi of boost when he's N/A, you don't include atmospheric pressure as part of your setup.
So basically, I'm saying I think he wants to run 14.5psi. Most people with 346's don't run 29psi, unless you're Harlan or someone
Edit/P.S.: I'm not 100% sure I'm right, but it's just TMK.
Old 05-10-2006, 03:32 PM
There we go... Now it's perfect. No more confusion! LOL I sure as heck don't plan on running 29# I can tell ya that! That poor ol T70 won't support it anyway!
Old 05-12-2006, 09:11 AM
MY99TAWS6's Avatar
I got a gt7 from lingenfelter.Its just a comp can anyway custom ground for lingenfelter I think?
Specs are on lingenfelter site.I figure they know a thing or two about turbo cars.
Old 05-12-2006, 03:46 PM
Josh@KY-Turbo's Avatar
02 LS6 cam for me. Alot of guys are making killer power and keeping near stock driveablity when not under boost.
Old 05-14-2006, 11:20 PM
I don't know, I'm still contemplating it. The new motor will handle 7 grand easy, would like a wider power band without losing too much bottom end, getting tired of having to shift ever 1.5 seconds!
