LS7, Z06, or Spec 3?
Old 05-11-2006, 04:55 PM
Scorch1's Avatar
Default LS7, Z06, or Spec 3?
This is my first M6 car so I'm not very educated with the clutch deals and all. I've owned 3 Automatic F-bodies, so I'm not new to the scene. My question is which is better, LS7, Z06, or Spec 3 or other?? I was leaning towards Spec 3, but now I see people talking about LS7 and I was also considering the Z06 since I've heard some good things about that. My car has 92,xxx miles on it, has Borla so far. Power mods I'm planning are longtube headers, a short shifter, possibly a cam, and possibly a 12 bolt. I do plan on keeping the car for a while so I'm sure the cam and 12 bolt will happen within 2 years time. Thanks for your help everyone.
Old 05-11-2006, 04:56 PM
Scorch1's Avatar
Oh and are upgraded master and slave's needed? If so which clutch package would I need to upgrade it with?
Old 05-11-2006, 05:45 PM
Shamson5.7's Avatar
Ive had the spec3 and it grenaded at 20k miles give or take. Im in love with my LS7 so thats where my vote goes.
I believe that at the very least you need an 01/02 master. Correct me if Im wrong guys.
I went w a Mcleod.
I bought my flywheel(ls2) clutch and pressureplate from T-56rebuilds. $550 shipped.
Old 05-11-2006, 05:47 PM
mrhzk35404's Avatar
LS7 gets my vote.
Old 05-11-2006, 05:48 PM
hurley711's Avatar
I have a Ls7/LS2 flywheel combo with the upgraded 02 master and so far so good. Engages real easy off of the floor it's almost like the clutch isn't there
mrhzk35404's Avatar
Yes I would.
Old 05-11-2006, 07:09 PM
Order 66's Avatar
Spec 3 works for me. I dont expect clutches to last for ever.
Old 05-11-2006, 09:16 PM
Technoman64's Avatar
Just got a LUK ProGold with Aluminum flywheel today. Hope to have it installed by the end of the weekend. Will let you know how I like it after the install.
Old 05-11-2006, 10:56 PM
LFNDUST's Avatar
I have a ls2/ls7 just installed haven't yet fully broke it in, but love it so far, I will let you know more once I get on it...oh and I upgraded slave and master to 01/02 hydrolics
Old 05-12-2006, 08:37 AM
bics56's Avatar
I just ordered a LS7 for mine. LS6 is a good piece but I heard they wont hold up to much track abuse...some have good luck though. Spec 3 I read a ton of stuff on them on here and from what I got out of it...quite a few of horror storries, some complain about chatter, and there is always the croud that loves them for the most part I read more bad things than good things. Before the LS7 I considered a RAM HD b/c I heard less bad things about them than spec but there were still quite a few people with bad experiances with them. The LS& I read nothing but great things about but keep in mind they are still pretty new and not proven yet. So I decided on the lS7 and figured if it can handle a C6 Z06 w/o any problems(so far) then it should hold up fine for me. One more thing I liked what I heard about the LS& was how streetable it is...that to me is pretty important since I do a lot of casual driving.
Old 05-12-2006, 10:16 PM
Scorch1's Avatar
So now I'm leaning to LS7...
Old 05-12-2006, 10:30 PM
cantdrv65's Avatar
Post
Id go spec 3+....better clutch than all three of your choices.
Old 05-13-2006, 11:05 PM
Rocktanski's Avatar
I would stay away from Spec.....have not heard many good things about them at all. There are many other good choices out there. Luk's gold series, Ceterforce, LS7, the Z06 clutch from the C-5 and Cartek's stage 7 clutch. Really depends on how abusive you are going to be on it. Remember, no clutch is "totally bullet proof" they will all fail at some point.
Old 05-14-2006, 01:17 PM
SPRAYED 01's Avatar
Spec stage III+ is my vote. Ive got about 5k on it and about 40 really hard launches at about 6krpm. My car dynoed at 548hp at the wheels and 703ftlbs and it feels perfect after every run. i would recomend it to anyone.. Ohya the only mileage my car gets is down town Chicago driving and the track. it does not chatter at all. Best clutch ever. I had the z06 and i smoked it in 3 months
Old 05-16-2006, 05:03 PM
Scorch1's Avatar
The mods that I listed were basically all that I plan on it. I do plan on being hard on it, but not all the time. Maybe just like day or so every two weeks if the opportunity arises.
Old 05-16-2006, 06:23 PM
z28drag's Avatar
used alot of clutchs on my m6 cant beat the spec stage 3 +.
Old 05-17-2006, 12:09 AM
Redneck Z's Avatar
Which ZO6 clutch did you have? C5 or C6??
Old 05-17-2006, 05:57 AM
Drove my car with the LUK Gold Series last night and the pedal feels great and it seems to hook really good. No chatter at all. I see that the original GM clutch was made by LUK also. I upgraded the slave and did the drill mod also.
The true test will be after a few more miles of use and a then turn the bottle on and see if it holds.
Old 05-17-2006, 08:09 AM
CompTA's Avatar
I see some people saying they upgraded the slave, and some upgraded the master, and some upgraded both...what needs to be upgraded for the '98-'00 cars? I thought it was just the slave...
Old 05-17-2006, 03:13 PM
99 Pewter TA's Avatar
Do them both since you are doing it anyways.
Quick Reply: LS7, Z06, or Spec 3?
