street tire pressure
Old 05-11-2006, 07:52 PM
95WhitetopTA's Avatar
Default street tire pressure
Tire manufacturer calls for 44 max press. door on ta says 30.what are you guys running for the best all around ride on the street.?Thanks
Old 05-11-2006, 07:53 PM
94greencamaro's Avatar
I usually run anything from 30-35 on the street
Old 05-11-2006, 07:58 PM
BlackBirdWs6Zzz's Avatar
I run 35. I just checked them yesterday. I got new tires at the end up winter and there is still perfectly 35 in there.
Old 05-13-2006, 09:17 AM
thanks
Old 05-14-2006, 10:06 PM
the_merv's Avatar
Max pressure is the highest pressure that you can have, and it won't affect the handling and tire wear. I run 33 psi, and have no problems. A softer tire will handle more, to an extent..
Old 05-14-2006, 10:11 PM
1993BlackZ28's Avatar
35 psi is where i keep my tire pressure
Old 05-14-2006, 10:12 PM
hashtagBMW
Speed Density's Avatar
I dont use tires.
Old 05-14-2006, 11:23 PM
lmao good one tony
Quick Reply: street tire pressure
