Tremec vs. Borg Warner T-56's
Old 05-12-2006, 12:56 AM
multiplicityZ's Avatar
Default Tremec vs. Borg Warner T-56's
I was wondering which transmission is the better of the two. i know most 6-spd f-body cars came with the Tremec as a standard option, but there was a Borg Warner T-56 as a "special" option that some could get, correct?
i was wondering what the true difference is between the two, and which one is best, because when i was looking to buy my 2nd camaro the dealer told me it had a heavy duty tranny, so i ran the RPO codes and it showed borg warner ?!?! I was just wondering if i passed up something good, or if i left trouble in the dust?
Old 05-12-2006, 06:17 AM
Keysplayr's Avatar
Aren't they the same?
Old 05-12-2006, 06:46 AM
peterock98's Avatar
My 98 has a Borg Warner.I believe Tremec took over there trasmission business in late 99.So all of the 2000 's & up had a tremecs.I would say the tremecs are better.
Old 05-12-2006, 07:40 AM
TAEnvy's Avatar
And Ive always been told the Borg Warners are stronger
Old 05-12-2006, 08:17 AM
peterock98's Avatar
I'am lucky then I have a borg warner
Old 05-12-2006, 08:37 AM
Camaroholic's Avatar
I've rebuilt both, and honestly, I see no difference. I've seen busted up B-W's, I've seen busted up Tremecs. They all fix the same to me.
The only minor difference enters in to play with the paper vs fiber backed blocker rings. Earlier transmissions (B-W) had the paper backed rings. They changed over to fiber (some call it "carbon fiber", I don't know if that's a misnomer or not, but it's black, looks like carbon, looks like fiber - but it doesn't look like anything special to me ) somewhere along the way. Supposedly it wears better than the hard paper backing material. Rebuild kits may "tout" their "carbon fiber blocker rings", but they don't even make the paper ones any more. You can't get them. So duh, they're all "carbon fiber".
Strength? IMO they use all the same parts. Is the Hecho in Mexico Tremec weaker than the B-W? I don't think so. They break the same.
Old 05-12-2006, 10:15 AM
TWS
TWS's Avatar
Yep. I've got 3 M6 cars and other than the stamping on the side of the case, I've never noticed any significant differences.
Old 05-12-2006, 10:26 AM
8a8mfh's Avatar
My 2000 six speed says Tremec on the main case and Borg Warner on the tail housing.
Never been apart either.
Just some useless information.
Old 05-12-2006, 12:32 PM
sdm1234's Avatar
Didn't Tremec buy out Borg Warner?
Old 05-12-2006, 01:23 PM
NastySSoo's Avatar
Ditto for my 2000. Also never been apart!!
Old 05-12-2006, 02:45 PM
8a8mfh's Avatar
Yes they did. I read a long story about this somewhere. Borg Warner seems to make a certain part for a given amount of time then sells it off to someone else. Like the ST10 they sold to Richmond.
Borg Warner is a huge company, I do HVAC work and they make parts for big a/c units too, occasionally we'll remove an old Borg Warner a/c unit from someones house. And the name tag on it is stamped, colered, etc just like it is on transmissions.
Old 05-12-2006, 03:18 PM
Keysplayr's Avatar
I thought Tremec manufactured T-56 transmissions for Borg-Warner as well as other companies. Borg Warner just stamped the parts with their brand name. No biggie, this is done all the time in every industry. Example: Samsung makes LCD monitors for Dell, IBM, HP etc. etc.
Old 05-12-2006, 04:31 PM
so they are the same with different names practically.
Its a good thing i probly have one of each then
Old 05-12-2006, 11:39 PM
sdm1234's Avatar
Same manufacturer, but creditted to whichever engineering coorporation initially designed it, with a name-plate stamp. Right?
Old 05-13-2006, 02:44 AM
NVR_SPDS's Avatar
My built tranny has a Tremec main case, and Borg Warner tailhousing.
Old 05-13-2006, 06:53 AM
sgarnett's Avatar
While that is indeed common practice, I believe the T56 was sold to Tremec, who moved production to Mexico.
Quick Reply: Tremec vs. Borg Warner T-56's
