Possible to run rest of piping for TSP Duals?
i just wanted to make sure its possible with the TSP duals because its dumped kinda close to the axel. just didn't know if it had enough room to go up and over
That's what she said...
It would be pretty tough to get the TSP kit over the axle, as you would have to have one on each side of the center section. Most people with TD's over the axle, make BOTH pipes cross the tq arm where the x-pipe is, then run BOTH sides over the passenger side. They then run across the back with one to have a pipe on each side.
I have my TSP duals run under the axle with absolutly NO problems, I would recommend it to anybody. You can see pics in my sig.
Originally Posted by YouCantCmyZ28
98% harder, there not made to go over because of the way the piping is run....at least thats what i hear from the blur and the tech at TSP
Best thing to do is go by a shop, get it on a lift, and see what you need to do. You will proably HAVE to scrap the PHR support.
