Anyone have a 2 bar VE table I can copy? Hp tuners
Old 05-16-2006, 03:05 PM
pwrtrip75's Avatar
Default Anyone have a 2 bar VE table I can copy? Hp tuners
As im going to start tuning my car for boost, does anyone have a VE table for HP Tuners i can safely start with? After converting my OS to 2 bar every square in the VE table says 519.
I could not find any in the bin repository.
email it to me if you could.
thanks,
green461@charter.net
info... 5.3L 8.6:1 comp. , 42# injectors, boosting off 1 bar in wastegate.
Old 05-16-2006, 03:47 PM
LS1TECH Sponsor
foff667's Avatar
https://ls1tech.com/forums/pcm-diagnostics-tuning/503989-hptuners-tuning-links.html this is the hptuners quick links thread...it links you directly on how to apply & setup your 2 bar map...please take the time to view the flash demo Scott put together.
Thanks
Bill
Old 05-16-2006, 03:50 PM
Assassin's Avatar
disconnect the charge pipe, tune the ve table, take the max reading say around 100kpa row, copy and paste to 210 kpa then x1.5, select from 100 to 210, and interpolate between verticle bounds.... that should get you close enough to finish... man I hope you have a wideband hooked up w/eio cable.... oh yeah and reconnect the charge pipe, lol...
Old 05-16-2006, 03:51 PM
7 Second Club
NicD's Avatar
Read the HPT help files. It tells you how to get started with a 2 bar tune. Don't just use somebody else's 2 bar table.
Old 05-16-2006, 04:14 PM
pwrtrip75's Avatar
just what i was looking for, thanks. that tutorial is awsome! I looked up "2 bar" and must not have seen it.
Old 05-16-2006, 05:58 PM
JimMueller's Avatar
So the process let's you convert the OS, but when you connect to write the file it asks for the license I take it?
I was playing around with it a few days ago on my '98 and I thought there was a fee to convert to a 2 bar OS. I just figured it wouldn't let you convert until you actually had the license. I wanted to play around with it more, but didn't want to get 'stuck'.
Not boosted, just want to get rid of the secondary table.
Old 05-16-2006, 07:34 PM
LS1TECH Sponsor
foff667's Avatar
the software now lets you play around with it...kind of a test it before you buy it deal...but yes once you attempt to write it it will ask you to license it.
Quick Reply: Anyone have a 2 bar VE table I can copy? Hp tuners
