Anyone have a 2 bar VE table I can copy? Hp tuners
As im going to start tuning my car for boost, does anyone have a VE table for HP Tuners i can safely start with? After converting my OS to 2 bar every square in the VE table says 519.
I could not find any in the bin repository.
email it to me if you could.
thanks,
green461@charter.net
info... 5.3L 8.6:1 comp. , 42# injectors, boosting off 1 bar in wastegate.
thanks,
LS1TECH Sponsor
https://ls1tech.com/forums/pcm-diagnostics-tuning/503989-hptuners-tuning-links.html this is the hptuners quick links thread...it links you directly on how to apply & setup your 2 bar map...please take the time to view the flash demo Scott put together.
Thanks
Bill
Thanks
Bill
disconnect the charge pipe, tune the ve table, take the max reading say around 100kpa row, copy and paste to 210 kpa then x1.5, select from 100 to 210, and interpolate between verticle bounds.... that should get you close enough to finish... man I hope you have a wideband hooked up w/eio cable.... oh yeah and reconnect the charge pipe, lol...
So the process let's you convert the OS, but when you connect to write the file it asks for the license I take it?
I was playing around with it a few days ago on my '98 and I thought there was a fee to convert to a 2 bar OS. I just figured it wouldn't let you convert until you actually had the license. I wanted to play around with it more, but didn't want to get 'stuck'.
Not boosted, just want to get rid of the secondary table.
