Need some opinions on rods
Im in the process of gathering parts for a S/C build. Im gonna run some Mahle dished pistons that should put me about 9.5 to 1 CR. Ive been looking at the Scat forged I beam rods(because their fairly cheap) I will go with a ARP 2000 bolt instead of the 8740's for added strength. Am I pissing in the wind with these rods? Will they support 600+ RWHP?
The Scat is a Chinese made rod. Some people have had good luck with them but I prefer to buy American made products so I use the Lunati Pro Mod rods that I know will support over 600 hp.
I can shift faster than you.
Dustin, I'd look at the Callies Compstar rods or the new Eagle LS1 specific rods. Both are on-center and would work well for your application. The Callies rods come with ARP 2000 bolts standard and it's an upgrade for the Eagles.
Jason
Jason
I've seen several turbo mustangs with SCAT & Eagle H-beam rods in the 1000-1200 rwhp range with standard ARP bolts 7/16" - both run in the $350-400 range.
If you want full piece of mind, spend another $120 on L-19 bolts and should be good to 1200-1400hp
Well, I decided to go with some Eagle H-beam rods with the ARP 2000 upgrade, I got them at a good price, and feel they will be stronger than the Scats.
Tahnks for the help.
