Torquer cam coming, which heads or stay with LPE LS1 ported
Old 05-19-2006, 01:27 PM
kapedogg's Avatar
Default Torquer cam coming, which heads or stay with LPE LS1 ported
Well, my mods are listed below. Right now I'm running the Lingenfelter top end kit with their GT2-3 cam. I'd like to step up to something a bit more agressive and I like what I see in the torquer V2 cam. Will their heads make for a good combo or do I need to go with a different set? There are a TON of head options and I don't really know much about them.
Old 05-19-2006, 02:38 PM
black01_WS6's Avatar
what are you going to do with the gt2-3 cam, I am thinking of going turbo and that would work great.
Old 05-19-2006, 02:48 PM
kapedogg's Avatar
I'll probably be looking to sell it. It's a fairly mild cam for NA, but people say this thing really wakes up with some FI. It is putting down some pretty good power though, and has pretty good torque down low. Fun for the street
Old 05-22-2006, 10:27 AM
kapedogg's Avatar
Ttt...
Old 05-22-2006, 10:38 AM
PREDATOR-Z's Avatar
Your heads will be fine. Just make sure you discuss cam specs with TSP to make sure you won't have PTV issues.
Old 05-22-2006, 11:14 AM
GuitsBoy's Avatar
were your ported heads milled at all? TSP said they ran the torquer on heads milled .015, but I was tight. Typical larger valves wont stick more than .005 further down the bore, so as long as youre not milled more than a few thou, you should be okay. I would double check with TSP or measure yourself just to be certain.
Old 05-22-2006, 12:56 PM
kapedogg's Avatar
I'm not sure what the mill specs were. it's their standard top end kit, so i'll have to ask and find out. i was told by a shop that did some work on my car that the heads were hardly touced.
Old 05-22-2006, 01:07 PM
PREDATOR-Z's Avatar
But the valves are bigger. So LSA and ICL plays a role here.
Old 05-22-2006, 02:46 PM
GuitsBoy's Avatar
Yes, the valves are bigger, but since we know the 15* valve angle, and the increased radius, we can solve to see how much further down they sit.
Running 2.050 valves, would have a radius .025 larger than stock. At 15* this would put the valve edge .0065 closer to the piston. (thats 6-1/2 thou.) That still leaves .0085 for the mill. Of course this does not account for larger than stock valve margins.
Old 05-22-2006, 03:16 PM
KGSloan's Avatar
good theory, but...
some head porters hang the valves lower or higher on the seat after the valve job. just using that method could be dangerous.
i know my 2.040 valves have about .030" less valve drop than stock, and that is not all from the bigger valves.
Old 05-22-2006, 04:06 PM
kapedogg's Avatar
Wow, I really need to get a better education when it comes to heads.
Old 05-22-2006, 04:36 PM
kapedogg's Avatar
I shot an email over to LPE to try to get some specs on the heads. Hopefully they'll work for me. Even if they do work, is there a better choice for heads with this cam? Will it make that much of a difference to make it worth spending the dough and performing the switch?
