I need a good converter for a 89 TTA
Old 05-19-2006, 04:19 PM
David Gordon's Avatar
Default I need a good converter for a 89 TTA
What would be my best converter for a TTA? I dont want to loose streetabilty nor do I want to sacrafice trap speed for good 60'. I play around from time to time on the street with those pesky LS1s and dont want to give up to much big end pull. Let me know what you guys think is best. Also is lock-up or non lock-up better for the turbo cars.
Old 05-19-2006, 06:41 PM
1BADDAM's Avatar
If you have a stock turbo or 44/49, stock D5 stall is fine for the street, especially for a mostly stock car.
Old 05-19-2006, 06:50 PM
HPT BANDIT's Avatar
I'd look to see what the GN guys are using.
Old 05-19-2006, 07:42 PM
So is stock D5 the stock converter. It will stall up pretty good but it takes a long time to build boost. It will stall to 2200 as it is but like I said it is slow to get boost up.
Old 05-20-2006, 10:22 AM
Yank's Avatar
We have converters for the Gn other turbo cars in lock-up on non lock-up
www.converter.cc
Old 05-21-2006, 02:08 AM
1BADDAM's Avatar
D5 is the stock converter. It stalls at ~2200-2400, at this point the car should start making boost, 1-3 psi. With the stock chip & wastegate components, full boost should be ~16.5 psi, and should get there pretty quickly, < 2 seconds (if I remember right). Sounds like you have other issues, possibly exhaust or vacuum leak, etc.
Old 05-21-2006, 02:21 AM
camaro75racer's Avatar
Check out http://www.edgeracingconverters.com/streetedge.htm
The 9.5" converters are great for the street...awesome spool times but still feel very tight for daily driving.
Old 05-21-2006, 11:10 AM
Thanks, should I use lock-up or non-lock-up?
The car has a street chip, adjustable wastegate, 3" down-pipe.
Old 05-21-2006, 04:34 PM
Lockup is good. Will keep the easy driving and help a little on mpg.
Old 05-22-2006, 10:56 PM
TTA299's Avatar
http://www.ptsnctb.com/ has nice converters ......
My 87 GN has a 3200 lockup and drives like any other streetcar and gets 1.58 60fts with 275/50/15 MT radials
