Hooker LT on stock internal, Befor 13.98@110 After 13.50@114
Befor my car run 13.98@110 , now after i install the Hooker LT with custom Ypip 2.5" , and i finish from ported MAF, TB and the finally, custom made flange cutout 2.5".
The different on the G-tech :
Befor 13.98@110 0/100 5.7sec
Now 13.50@114 0/100 5.1sec
What is your opinion guys ??
Re: Hooker LT on stock internal, Befor 13.98@110 After 13.50@114
Fahad,
You'll probably have to use a more accurate scource than a G-tek. You should be probably in the low 13's to high 12's.
--JF
--JF
To put a perspective on things, my car runs 12.84 @ 111 with a 2.0 60'
You probably picked up 4/10 but I'm sure your faster than 13.5 <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
13.98 and 13.50 seem like pretty high numbers so I wonder about the accuracy, but whatever the numbers you definately seem to have made your car faster. Being from Kuwait maybe it's the desert heat slowing you down. <img border="0" alt="[burn out]" title="" src="graemlins/gr_burnout.gif" />
If the G-tech is accurate on ET's, but off on MPH it would be tough to guage how much power your car is putting out. Many people have said MPH is one of your best sources for determining what kind of power your car has and what it's potential is.
ET's don't really matter as much because they can be a function of how good of a driver you are which may not have anything to do with what your car is potentially capable of.
Fahad
Congratulation man for your new stuff , seems that your car is getting better and better , Mashalla <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Fahad , you better go to the track and test your car , call me when you want to go .
Take care and good luck <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Salam
Salam
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by simpsonsruleWS6:
<strong> Being from Kuwait maybe it's the desert heat slowing you down. <img border="0" alt="[burn out]" title="" src="graemlins/gr_burnout.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Hey man , good morning , are you sleeping or what <img border="0" alt="[boring]" title="" src="graemlins/gr_zzz.gif" /> ??? some places in Kuwait now are in 0 C degree and less ...... what heat you are talking about ??? we are playing skati on our ice <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
hmmmmmm , or maybe you are meaning something else ?? <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" /> <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
becarefull
becarefull
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by JF WS6:
<strong> If the G-tech is accurate on ET's, but off on MPH it would be tough to guage how much power your car is putting out. Many people have said MPH is one of your best sources for determining what kind of power your car has and what it's potential is.
ET's don't really matter as much because they can be a function of how good of a driver you are which may not have anything to do with what your car is potentially capable of. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thank you man .... YOU ARE THE MAN <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> .... its a good point .... thats what I am trying to tell everyone about it .... it doesn't metter what car's E.T. is ..... the MPH is more important
thanks and take care <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
!Dial-up Director
The mph on the Gtech is higher then what you see at the track because at the track your trap speed is the average over the last 66ft. Whereas the Gtech gives your final speed, not an average.
Justin
Justin
The G-Tech may not be the most accurate thing as far as times, but it seems to be fairly consistent, so it gives a decent idea of 'before and after' changes.
I heard that the ET is fairly close to the track time, but the MPH would be off due to the way the Gtech calculates it
Thanks guys,
Ok..What is the better than G-Tech ?
After one or two weeks i will have lower box, what do you think whene i install it , I mean did will be better in MPH ? and your opinion plz in this!
Thanks
Fahad
Thanks
Fahad
The GTech has proven to be very accurate and consisten, up to a point. As already pointed out, MPH will be a little high. ET's will be higher on the street than at the track because of traction issues. But run-to-run, the times should be right on.
I have seen several guys do GTech readings at the track, and they were consistently within .05 secs of the track times.
