Plastic pieces underneath the front of our cars?
I have a moroso cai and where the filter is located is
like behind all of the plastic pieces that you have to
unbolt to get to all of the turnsignals and stuff, and i was
wandering if I took all of the plastic stuff off if I could
tell a difference since it is getting more air to the filter?
Also would it hurt anything by keeping all of that stuff off,
and has anyone ever done this?
yeah it makes it easier to work on but, its also a hinderance because if you drive on dirt roads or in the rain you run a higher risk of gettting it dirty faster and hurting your car due to the water in the filter from the rain
I took the splash guards off years ago. I don,t daily drive it anymore but even when I did I never had a problem.
You will have to clean the filter more often.
I rigged up a ghetto ram air from dryer duct hose that directs air to the filter, it looks silly and I get ragged on all the time for it but it does work.
What I did was cut out the metal out of the area where the Air Box is, extended and dropped the box down into the wheel well. Then I cut out a square portion, cut the Air Dam part that was directly infront of it, and made a scoop out of Aluminum. It pulls all the cold air that is coming under the car in that area.
Originally Posted by Shon Herron
the only thing left is the air dam.
Originally Posted by blind527
Hey Shon, I finally ripped out my carpet, and bought some lightweight carpet at Menards. Weren't you talking about a plastic piece under the dash under the pedals, that extends to the passenger side of the car? Didn't you say that was like 13-16 pounds or something?
Post pix of the carpet once installed. I have not made that purchase yet....
I spun out at 130mph when too much air got up under the nose when those pieces were off. After putting them back on, I've never even come close to that--even up to 140mph.
Originally Posted by Dragframe
i d ont realy imagine those making that much a difference..
Originally Posted by lt1maro
i think the front air dam also keeps your car running cool also cuz it forces air onto the radiator
Originally Posted by 383LT1S10
Scary feeling huh? You seem to have ended up ok.
After that I did a lot of study on 4th Gen aerodynamics and realized just how critical all those pieces are. To make some really significant improvements would not cost too much, but the non-racers on this site would scream "rice" if they saw what that really involved.
