Anyone know how......
to set the TPS. My car is surging and I want to check and make sure that the TPS is set at the correct voltage. Also What is the correct V??? TIA.....Scott
Re: Anyone know how......
You can't really set the TPS. You will need to back probe the v-ref wire, and put one lead to a known good ground. Voltage at idle should be less than one volt, and at wide open throttle around 4.5 to 5 volts.
