To tune or not to tune !?!?!
Old 05-23-2006, 03:10 PM
2KSS's Avatar
Default To tune or not to tune !?!?!
Well I just put some long tubes, y-pipe and 02 simms on my SS this weekend and I was wondering if I should have the car tuned ?
Any comments ?
Old 05-23-2006, 03:14 PM
bmfcamaro's Avatar
if its just that i wouldnt until you get some more. unless thats all your going to do. or you can buy a suite and do it yourself. you shouldnt need it tuned unless the car is acting up though.
Old 05-23-2006, 03:25 PM
RedHardSupra's Avatar
LT's make 10-12 point difference in VE in midrange, they allow a lot more air coming in, which in effect causes lean condition. unless you want it dangerously lean and knocking (and effectively pulling timing) then go ahead, don't tune.
Old 05-23-2006, 03:39 PM
bmfcamaro's Avatar
nevermind then. i ran mine for a while without tuning. i guess you shouldnt, but every car is different.
Old 05-23-2006, 03:42 PM
no, it isn't. why do you put all the 'performance' parts on it? to make it flow more air! what happens when it flows so much air that the PCM cannot compensate for it by itself? it goes into panic mode and pulls timing, which decreases performance. so adding parts without compensating for them in the PCM basically cancel each other out. so what's the point?
Old 05-23-2006, 04:11 PM
bmfcamaro's Avatar
my post just says if hes getting more parts to hold off. paying for a tune can get expensive. if hes not going to do more than get a tune. i never said he shouldnt. thats just my opinion. many people on here have done that. its not unheard of. people drive around in small cams with no tuning.
side note
doesnt the maf compensate for the increased air?
Old 05-23-2006, 05:22 PM
2KSS's Avatar
Well I'm running a Z06 MAF if that make any difference as well as a TSP lid. But I am planning on installing a TSP Torquer Cam in about a month !! So I guess I should wait for the tune until then....
Old 05-23-2006, 06:58 PM
joecar's Avatar
If you tune, you will maximize/optimize your investment/mod.
Old 05-23-2006, 07:05 PM
txhorns281's Avatar
side note
the maf does not follow any sort of adaptive function. It's accuracy rests solely on user calibration, from factory form, the MAF airflow curve is formulated for stock airflow requirements. Then you have people going and messing with the formula, increasing airflow efficiencies, the MAF will not magically understand these modifications. The best the PCM will do, is detect lean burn from O2 feedback during closed loop fueling and adjust fuel via trimming.
Old 05-25-2006, 12:50 PM
Restricted User
fenix99's Avatar
wait for the cam and TUNE it
Old 05-25-2006, 12:57 PM
red_pacu1's Avatar
cam in a month? yeah wait n get it done at the same time, u could get another performance part for the money u'd be saving if u waited.
