List for the rest of the mods
Old 05-24-2006, 02:21 PM
Azthrei's Avatar
Default List for mods
Ok, i'll post up here what i've got so far, and what i'm looking at getting later, and you guys tell me if you'd do anything different on the last list.
What i've got for the engine-
396 LT4
-Forged 396 4-bolt main LT1 block
-AFR 227cc LT4 heads, with matching LT4 intake manifold
-AS&M Monoblade 58mm throttle body
-Custom grind cam, something like .254/.266 .622/.638 112 LSA
-All supporting pieces: 42# injectors, new opti, new MSD wires and 6AL ignition system with blaster coil and wiring harness, etc...
What i'm looking at getting here in a week or so -
-Tranny rebuilt with carbon kevlar blocker rings, new 3 gear, steel shift fork, billet aluminium keys
-9" rear with 3.73 gears
-LS1 aluminum driveshaft
-UMI DD SFC's
-UMI Adjustable torque arm with tunnel brace and driveshaft saftey loop built in
-Adjustable panhard bard
-Upper panhard bar with relocation kit
-Lowerings springs, not sure which ones, something like 1-2" drop
-New shocks, looking at something not too expensive
I've already got a non-adjustable panhard bar, and lower control arms for suspension, but not much else. What do you guys think of the current combo, and then complimented with those suspension parts? Also, if you would change anything in that second list, what would it be?
Old 05-24-2006, 02:33 PM
lt197formula's Avatar
Damn sounds like a nice setup I would suggest a dynaspark instead of the opti so you wont have to deal with it again, why not 3.90 gears? and if you have long tubes that 1-2 drop will kill them so you should think about that.
Old 05-24-2006, 02:50 PM
Azthrei's Avatar
I do have longtubes, they're dynatech with the removable collectors. And for the springs, I would probably end up only doing a 1-1.5" drop max, just to give it a better stance for auto-cross if I decide to do something like that.
Old 05-24-2006, 05:50 PM
Azthrei's Avatar
No one else has any comments on the planned setup?
Old 05-24-2006, 07:54 PM
Quick96ss's Avatar
if it is a street driven car then 3.73's are good
Old 05-24-2006, 08:19 PM
Azthrei's Avatar
The car will be used for weekend kinda stuff, and maybe to work and back during the week. Kinda depends on how it runs, and how much gas it goes through.
Old 05-24-2006, 10:18 PM
Quick96ss's Avatar
I have heard that those are the best gears for a street / strip car with an automatic
Old 05-24-2006, 10:32 PM
NotACop97Z's Avatar
Dont forget the LCA relocation brackets
Old 05-24-2006, 11:31 PM
Azthrei's Avatar
I've got an M6 that will be going with this little setup. Also, the LCA relocation brackets will either be part of the rear end that is coming, or i'll buy some seperately. This build has just taken so long, and has been so expensive, that it's hard to remember all the parts that have gone into it, and what's left to get.
Old 05-25-2006, 12:31 AM
imnotplutonium's Avatar
i hear the ls1 d/s are weak when you are making the power you are probably looking at. might stay with a steel one?
Old 05-25-2006, 12:53 AM
hashtagBMW
Speed Density's Avatar
Get a dennys Drive shaft, strong and light.
Old 05-25-2006, 09:06 AM
yea I second the Dennys Nitrous ready 3 inch steel driveshaft, just about unbreakable and lifetime warranty I think.
Old 05-25-2006, 11:21 AM
Azthrei's Avatar
The only issue I have with getting a Denny's, is the pricetag on those. If I recall, it's something like 800 for one, but I haven't looked in awhile. That would max out my budget, and then some, and i'd have to save even more for tires and registration stuff. I might get it, but it really depends on whether or not I have the extra for tires.
EDIT:: Looks like I was wrong, it's more of a $400 pricetag right now.
Quick Reply: List for the rest of the mods
