What do i need to use a MAP sensor instead of MAF?
Old 05-25-2006, 01:42 AM
blackbird345's Avatar
Default What do i need to use a MAP sensor instead of MAF?
I've installed a turbo but what is the advantage of a 2 bar map sensor over the MAF sensor?
Old 05-25-2006, 02:17 AM
MECHAM's Avatar
2-3 bar...your ecu knows what boost is via the 2-3bar map sensor and can add fuel accordingly. more than likely the maf sensor will be maxed out by 3-4k pending yr application..after that you are shooting in the dark. the 2-3 bar map will take care of that
Old 05-25-2006, 05:21 AM
mistermike's Avatar
You will need a tuning package that provides a modified operating system for the ECM. I'm using EFI Live 2 bar O/S with excellent results. MAF is sitting in a corner of the garage.
Old 05-25-2006, 10:03 AM
So would EFILive be acceptable? What else would I need? The sensor itself correct? Where do I install the sensor on the intake? Thanks in advance.
Old 05-25-2006, 03:11 PM
98turbls1's Avatar
What year of vehicle do you have???
Old 05-25-2006, 08:10 PM
I have a 99 F body
Old 05-25-2006, 08:38 PM
98turbls1's Avatar
EFIlive will work then...Yes you will need the sensor which you can get several different places...
Old 05-25-2006, 09:19 PM
So all I need is the sensor and tuning? Where does the sensor plug in?
Old 05-26-2006, 01:05 AM
98turbls1's Avatar
The back of your intake manifold...
Old 05-26-2006, 03:26 AM
So I can use both the MAF and the 2 bar sensor? Is it difficult to tune?
Old 05-26-2006, 03:55 PM
coop5885's Avatar
if your using the 2 bar then you will no longer need the MAF. The MAP sensor will adjust your fueling
Old 05-27-2006, 05:14 PM
How difficult will it be tune? Can I just download a standard tune as a baseline or do I have do it all from the ground up?
Quick Reply: What do i need to use a MAP sensor instead of MAF?
