STS owners, oil return?
I have been running my STS for about two years and I really don't like the oil return. Anyone do anything other than drill the pan?
http://www.w2wpowertrain.com/pc-53-3...k-for-ls1.aspx
Has any one tried this for an STS? Where are you guys putting the fitting? The rear of the cover? Any photos?
http://www.w2wpowertrain.com/pc-53-...ck-for-ls1.aspx
Anyone put one of these on a car with stock manifolds and cats?
With a oil cooler, there is positive oil pressure all the time on both the feed and return. The return dosent just dump in to the oil pan, it feeds the rest of the oil system. There was a guy on the sssilverado board that tried one of those sandwich things that goes in between the oil filter and the pan to feed his remote turbo and it pushed oil past the seals like a ****. This would do the same thing. You can try it, but I got a $100 that says it won't work.
The back pressure of the oil going back through the motor should be take up by the sts oil pump. I am only diverting a small diameter fitting from the area.
Can I have my $100 now?
Just a joke, I think I am going to tap the pan, thanks for your help.
