QA1 setup
QA1 setup
You guys running the QA1 shocks all around what settings to you have them at (front and rear)? If you have the extreme duty torque arm what pinion angle do you have it at? I ran my car last night and I could'nt hook up for **** (yes I have E.T Streets and doing good burn out)
I had the front shocks @ 4
The Right rear was @ 3
the Left rear was @ 2
then I tried
3 in the front
the right rear was @ 2
left rear was @ 1
Pinion angle I have at -2
then I tried
3 in the front
left rear was @ 1
Thought maybe your control arm angle might mess up your traction. I'm guessing you have M6? Anyway, about the cam, I like the cam as far as seat of the pants and sound goes. Tried dynoing a couple times with a failing optispark so I didn't get anything good. I was as a matter of fact looking at the dyno charts today from Thunder Racing last summer and judging by the curve, it looks like I might have hit 440 if it peaked at 6800. I have since swapped to A4 and Denny's NR shaft so I will lose some. I would hope to say I could dyno 425 at best. Tried running the 1/4 last fall only to break my transmission tailshaft housing so I never got a good pass for a time. Hope to try the 1/8 in the next couple months. I haven't been able to spray this cam so I can't say much there either. One thing I wish I had done was get this on a 110 lsa for a little more peak power and some more nastiness. Your duration isn't too low or anything so have you thought about trying a higher rocker ratio?
with singal adjustables I had the best luck with 3-4 on the rear and 1 or 2 on the nose depending on traction. The shocks were actually desighed for stripped cars so us guys with full wieght have problems with the nose dropping to fast.
I fixed this by going to the DA QA1s on the front. I run 6 on the compression and 1 on the rebound. This lets the nose come up fast but not come completely back down until just after the 60ft or so. It made a huge difference on consistancy and traction.
I am planning on adding a Trans Brake and new ignition system next. We will see how a two step- trans brake- N2O launch will hold next
Originally Posted by dhdenney
What kinda springs? Maybe your HALs are working against your springs? Just shooting in the dark here...
I used to hook up with my old LT1 witn no problems
I have Qa1's and run the frontsa at 1 and backs at 3. You want the car to rock back quite a bit. I have 17" et streets in back, and stock WS6 rims/tires up front. I have Global West's Trac Link torque arm. I am not sure at the exact pinion angle, but when I do a burn out, the back of the car lifts up, meaning the fender gap grows as I start my burn out. I pull 1.6's with this setup, which is very similar to yours.
Ride height is stock, rear tire pressure is 19psi, fronts are 40psi. Car weighs 3400 even, with me in it. Hope this helps.
Moderator
I need to check the pinion angle on mine, not sure what its at with the new torque arm, also a Track Link set up. I run the single adjustable on all four, drag springs up front with no sway bar. My car is heavy as hell, but at the track I find 1 works the best up front with 3 in the back. Any thing more than 3 in the back the car gets to bouncy in the back. On the street I set the fronts at 7 and leave the backs alone. With my heavy *** car on the street if I hit a corner to hard it will body roll and compress the shock on what ever side its putting weight down on prety hard. They work well, I just wnat to see what they'll do on a tire
We always run the rear as tight as we can if the track is there and the fronts as loose as they go. If the track is a little less prepped the rear shocks might need to be looser.
I am still running stock shocks/springs and think it is doing pretty well....BUT we race at REALLY well prepared tracks.
