unreal
Old 05-28-2006, 06:31 PM
Big Budda's Avatar
Default unreal
just installed a tsp 224r cam, prc duals springs,powerbond underdrive pully in my 99 z and had it dynoed
results were 327rwhp and 334 rwtq
granted i have eldlebrock block huggers and a chockmaster cat back
Shouldnt it have dynoed at least more than 7 horses over a stock 2001
Old 05-28-2006, 06:41 PM
chrs1313's Avatar
cam should have given at least 35 hp over your previous numbers with a tune
Old 05-28-2006, 06:54 PM
cantdrv65's Avatar
Post
that catback is probably costing you in the neighborhood of 25 to 30rwhp. Getting a cutout installed would be the cheapest fix.
Old 05-28-2006, 06:56 PM
Mr. Luos's Avatar
Seems like a TON for just a catback.
What pushrods do you have in there with that cam??
Old 05-28-2006, 07:09 PM
Big Budda's Avatar
7.4 hardend comp with harland sharp 1.7 t roller rockers
Old 05-28-2006, 07:30 PM
blkbird's Avatar
That doesnt sound right at all.....
Old 05-28-2006, 07:37 PM
Mr. Luos's Avatar
Can you post the chart?
Old 05-28-2006, 08:16 PM
Big Budda's Avatar
here it is
Old 05-28-2006, 09:34 PM
TV559's Avatar
Is the car Tuned? Because I went from 318Hp Baseline with a Cam and 371Hp with a dyno tune. Also a Cut-out helps out big time so I would look into getting one.
Old 05-28-2006, 09:54 PM
cantdrv65's Avatar
Old 05-29-2006, 09:56 AM
DocEwww's Avatar
Is it an untunned auto w/ Flowmaster c/b? That'd make sense.
Old 05-29-2006, 10:09 AM
98SS2836's Avatar
looks like you have valve float starting at 6000 rpm or its pulling a **** load of timing.
Old 05-29-2006, 11:06 AM
Big Budda's Avatar
m6
alum flywheel
slp lid
harland sharp 1.7 rockers
comp pushrods 7.4
all the free mods
dyno tuned by gmr
Old 05-29-2006, 12:10 PM
Moderator
davered00ss's Avatar
Your saying the car has edlebrock headers & flowmaster exhaust? you should be over 330rwhp with lid, Headers & cat-back. Is your car throwing any codes? I would get a tune and find out what's up.
Old 05-29-2006, 12:12 PM
Moderator
I just did Headers & and Ls6 intake on a friend's 99 Z, and after the tune he was 345rwhp/355rwtq. Car has Kooks Lt headers w/ catted y-pipe, SLP pully, ls6 intake, Ported TB, Loudmouth cat-back.
Old 05-29-2006, 12:43 PM
Big Budda's Avatar
not throwing any codes either
Old 05-29-2006, 01:02 PM
Moderator
So your car only did 307 w/ Headers?
Old 05-29-2006, 01:03 PM
allngn_c5's Avatar
Hey man looking at your graph ( I wish it was clearer) it looks like you gained power on the Max side, but what's cool is you are making more power 500-700 rpms earlier then with your old cam. So not a total loss. Did you say this was tuned or untuned?
Further tuning could yield more power. Hope things workout for you and your car.
GOOD LUCK !!
Old 05-29-2006, 01:13 PM
66deuce's Avatar
from the graph it looks like your peaking at about 5600rpms,if i'm reading it right.i think that cam should peak around 6000-6200rpms.which tells me it might be installed with too much advance.did they advance it when installed?what's the LSA? my TR220 114+4 LSA peaks around 5800rpms.and like was said earlier your catback and headers aren't helping either.
Old 05-29-2006, 02:38 PM
Big Budda's Avatar
i installed it stright up(dot to dot)
224/224 .581 .581 114 lsa
