what gears do i have
Old 06-04-2006, 07:37 PM
phillyz28's Avatar
Default what gears do i have
i was wondering... i got my car a while ago, just never figured out what gears i have, or if there are any mods done to my car.
some of my friends seem to think so but they have never driven or sat in an ls1 other than mine, well i havent either.. so they really have no idea.
Old 06-04-2006, 07:38 PM
V8pwrdz28's Avatar
it would help if u told us what car u have
Old 06-04-2006, 07:39 PM
DaGeneral's Avatar
Well wth do you have ? M6 ? Huffy ? A4 ?
Old 06-04-2006, 07:42 PM
phillyz28's Avatar
haha, oops.
i have 99 A4 Z28
JerseyLS1TA's Avatar
look on the door, there is a sticker that gives you rpo codes. GU2 - 2.73 l GU5 - 3.23
Old 06-04-2006, 07:57 PM
Tainted's Avatar
if you can select 1st gear you got 3.23
Old 06-04-2006, 08:07 PM
phillyz28's Avatar
GU-2 -- 2.73 ... what does that mean?
Old 06-04-2006, 08:18 PM
Tainted's Avatar
it means you got 2.73 gears like me. shitty for acceleration but have a wicked high top speed
Old 06-04-2006, 08:38 PM
phillyz28's Avatar
cool... although id rather have quicker acceleratoin
so what kind of top speed are u talkin about here and whats the best mod to compensate and get the quicker accel?
Old 06-04-2006, 08:39 PM
Iron Sights's Avatar
Read the stickies man. There's no one magic mod. You need to pick a goal and then figure out what mods you need. There are an infinite number of ways to achieve "quicker accel."
Old 06-04-2006, 08:51 PM
99camarosupersport's Avatar
did your door say GU2 or were you just asking what that meant ?....you can always just change your rear gears out to what you want (4.10=wicked accell) and it's fairly cheap at $110. and i agree with iron sights. also remember when you start building everything up the weaker stuff tends to break....so 1 mod can equal 5. if that makes sense, just a fair warning.
phillyz28's Avatar
yea yeah i know, i know... stickies
Old 06-04-2006, 09:02 PM
They won't fail you; just take the time to read them. You won't regret it. Just remember modding can be likened to taking drugs; it is damn hard to stop once you start.
Old 06-04-2006, 09:03 PM
phillyz28's Avatar
my door says GU2... and yeah that makes a lot of sense. if i were to swap out my 2.73s for 4.10, would that restrict my top speed then (not a huge concern i guess -- 140 is fast enough for a DD)
also, are there sponsors for the gears or where would i get them from? guess i should do some more research
Old 06-04-2006, 09:36 PM
blackbirdls1's Avatar
i can select 1st gear... but my door has a Gu2 code.
Old 06-04-2006, 09:37 PM
phillyz28's Avatar
what does that even mean... select 1st gear
Old 06-04-2006, 09:38 PM
LS1Formulation's Avatar
You probably don't want 4.10 gears in a DD anyway. 3.73's will be just fine. A lot of people with A4 cars think a high stall converter is just as good a mod as gears are. It'll drop your E.T. just as much. Just depends on what your goals are for the car. BTW, on a 2.73 car, the gear selector won't let you shift into first gear.
Old 06-04-2006, 10:05 PM
phillyz28's Avatar
i was searchin for a while about a stall converter but all i could find was that it was a good first mod, never really got a grasp of what it does or how it helps.
why not get a 4.10 in a DD... my goal is a quick car, real quick. I'm probably not goin to the track at all b/c i'm always real busy. i dont need a 10s car or anything, that and i cant afford a 10s car
Old 06-04-2006, 10:14 PM
MYLS18U's Avatar
I would call the dealer and give them the last 8 digits of your vin #. It turns out my car came with 3.42's
-Gabe
Old 06-04-2006, 10:21 PM
phillyz28's Avatar
i should do that.... thing is though is that i bought the car used at an auction.
no idea who the previous owner was or if anything was modified on the car. a good starting point i guess would be to get that figured out
