Dominator 427 Goes 614 rwhp / 555 rwtq
Old 06-05-2006, 08:10 PM
LS1TECH Sponsor
mikey's Avatar
Default UPDATE: Track Results: Dominator 427 Goes 614 rwhp / 555 rwtq
We just finished up a customers 2000 Camaro with our solid roller 427 LS2. I was pretty happy with the numbers considering the driveline. Moser 12 bolt with 4.30 gears, McLeod twin disk clutch with steel wheel, Denny's Nitrous ready driveshaft.
Engine uses ET 265 heads and a custom cam. Compression is in the 13.5:1 range. I'll post the graphs when I get back in town. Out racing
Mikey
Old 06-05-2006, 08:29 PM
SlickVert's Avatar
Wow!
Awesome HP/TQ!
What rockers did you use?
Tell us about the set-up.
Old 06-05-2006, 08:31 PM
LS1TECH Sponsor
mikey's Avatar
You can only use the Jesel rockers with the 265 heads. They're really expensive! Crank is a Callies Racemaster, Lunati Pro Billet Rods, Custom Diamond Pistons. The rest is secret
I should mention that we use a FAST 90mm intake for now. Although it was heavily ported and worked, the engine was starving for air up top. Peak power came in ~6500 rpm. We're talking to a sheet metal intake guy at the moment
Old 06-05-2006, 09:27 PM
383ss's Avatar
very interested in seeing the graphs... the ETPs still don't seem to be blowing away stock heads IMO. tosto's solid roller 421 is putting out a little more power with ls6 heads... he does have a sheetmetal intake though.
still an ASSLOAD of power all motor
Old 06-05-2006, 09:33 PM
tlaselva's Avatar
Nice power!
Take a look at the Wilson Intake.
Should help with the breathing up top!
Dyno graph would be great!
LS1TECH Sponsor
foff667's Avatar
running a maf or SD tune? Have to ask with all the debating going on
Old 06-05-2006, 09:48 PM
LS1TECH Sponsor
mikey's Avatar
LOL, ran it both ways. Used a custom SD EFI Live tune and an OEM OS MAF based tune. No power difference. No idle difference. When this engine is allowed to breath with a better intake, you can bet the MAF will become a restriction then but now it is not.
Old 06-05-2006, 10:04 PM
Nickn20's Avatar
I bet there is 50 hp hiding in that intake manifold setup nice numbers
Old 06-05-2006, 10:07 PM
Skelton's Avatar
Good sheetmetal intake, DFI and your set. Thats great #'s through a maf.
Old 06-05-2006, 10:32 PM
69chevy's Avatar
Impressive numbers. Wish I had something like that
Old 06-05-2006, 11:21 PM
Big-DEN's Avatar
The tq tells a story of huge potential, just imagine if you can keep a similar tq, mv it over 500rpm to the right and move the hp peak to 7500 rpm.
Talking about 700 or so rwhp with 550 rwtq
Old 06-05-2006, 11:45 PM
Super Hulk Smash
JakeFusion's Avatar
What about the carb style intakes? I'm sure if properly ported, they could help out a ton and wouldn't be insanely expensive.
Old 06-06-2006, 02:51 AM
ls1408cp's Avatar
I would think that thing would dyno 60-100hp more with a sheetmetal
Old 06-06-2006, 08:14 AM
bad95killer's Avatar
Damn very impressive numbers Mikey & as they stated above there's more left with a sheetmetal intake
Graph mikey
peace
Old 06-06-2006, 08:26 AM
speedracer5532's Avatar
Congrats Mikey. Is this the black camaro that was at Cecil last November when I was there?
Old 06-06-2006, 09:39 AM
LS1TECH Sponsor
mikey's Avatar
Yes John, that's the guy. Took us long enough eh?
Mikey
Old 06-10-2006, 11:27 AM
8 Sec Tuner
Mike TexaSS's Avatar
Great numbers. Is that with a sheetmetal intake? Or ported FAST?
LME is almost finished with our 455 cid LS1 with ET 265's big solid roller Becks Sheetmetal with accufab 105 mm TB. We are also shooting for 13.5 comp ratio.
This is going into our 1996 Impala SS..
Old 06-11-2006, 08:04 PM
LS1TECH Sponsor
mikey's Avatar
It's a ported FAST 90mm for now. We are talking to several folks about a sheet metal intake and some other things
Mikey
Old 06-11-2006, 11:56 PM
Beast96Z's Avatar
Mikey, see sig. for intake solution for the 265's.
Old 06-12-2006, 05:24 AM
LS1TECH Sponsor
mikey's Avatar
Yep, looking at that one too
Quick Reply: Dominator 427 Goes 614 rwhp / 555 rwtq
