Tell me its possible to get better than
Restricted User
23% Torque Converter Slip? I have been meaning to replace this TC, but cuz it "works" I have left it alone..now its getting down right irritating with how much I think I am leaving on the table. Not even sure how much I am leaving behind? It feels like it plateau's on the top half and then I calculate the slip...no wonder So, I'm in the market for a new TC. I should be able to match up a TC to get me more efficiency than this right?
Charlie
Charlie
That sucks. My midwest was at 93% last year. I had them loosen it up over the winter and went to far. It was stalling at 4800 on motor and i was going through it. I just did the calculation and it was 85%. I pulled it out last week and am waiting for it to come back. I had them tighten it back up about 600 looking for a 4200 stall on the brake. then some bigger jets I have the trans R&R down pat. it took 1 hr 45 min by myself on jackstands in my garage
Restricted User
So you'd think I was leaving a lot left up in the TC huh Sometimes I really wished I listen to myself...I knew I should have addressed this earlier. Oh well, I can do the TC Swap (on a lift) in under 2hrs casually wrenching away now, so will have to keep this in mind when the move is done.
that is alot of slippage. I think yanks are pretty efficent from what i have seen. I am waiting on mine. I will let you know how it works out on my 408 with a 200-300shot
Charlie
Charlie
now i am glad i got the yank
Originally Posted by slowredz
How do you guys calculate this figure
Example:
Let's say ur goin through that traps at 125 mph at let's say 6500 rpm and for 6500 rpm with whatever combo of rear gears and tranny gear ur usin the calculator says you should be at 130. Now you divide 125 by 130, and you get about 96% efficiency, which means you only had about 4% slippage.
Restricted User
Devon, I simply use TCI's trans slip calculator on their site Plug in the info...**** out the slippage..mine is getting worse I swear. I am looking into getting a Coan now. Tried continental, but website is down and no answer phone.
Restricted User
I was tossing around NCRC, but a few guys I know said they've had both and given the opp to get one or the other, they'd go Coan. Yank is an option, I had a old-*** 3k stall back when I got my car, it rocked the house for as small stall it was. John @ Fuddle can make one too. I just need one I can count on to work with my setup, and not have to worry about bolting into the LS1/TH350 combo.
loudmouth ls1 do you spary all 300 of the line. I was going to run a progressive setup but maybe not. The way it sounds my converter is setup very similar to yours.
