Idle surge???
Old 06-07-2006, 08:45 AM
WickedWS.6's Avatar
Default Idle surge???
After my car warms up it will surge or hunt for idle for about 5 minutes. This started after installing my convereter would this be a tuning issue or what?
Old 06-07-2006, 09:05 AM
SSpdDmon's Avatar
other mods?
Old 06-07-2006, 10:23 AM
ringram's Avatar
Should be just a tuning issue IMO.
Old 06-07-2006, 10:27 AM
98redorangeta's Avatar
A little surging is normal i had the same problem but its only about a 50-100 rpm suge its not like cam surge where it will almost die. I added 50 rpm to my in gear table and it hasent been doing it. Also idel air in gear table adding some there should help.
Old 06-07-2006, 01:20 PM
2001NBMZ28's Avatar
Had the same issue after my TC install, sometimes even dieing when coming to a stop. Increasing in gear idle solved mine.
Old 06-07-2006, 01:38 PM
WickedWS.6's Avatar
Cool thanks for the input guys. other mods are Hooker LTs borla and no emissions equipment those are all of the engine mods.
Old 06-08-2006, 04:13 AM
98A4LS1's Avatar
Increase the in gear by 25 rpm increments until the surging goes away. I had the same problem.
Old 06-09-2006, 12:36 PM
Doc
Doc's Avatar
Do you have a way to log your running airflow? Have you tried adjusting your timing?
