General Maintenance & Repairs - Another turn signal problem
View Full Version : Another turn signal problem
MJE95GAGT
06-07-2006, 07:52 PM
Alright I did a search and I am still puzzled. A couple weeks ago my front passenger turn signal went out, didn't blink just a solid green arrow on the dash and the bulb wasn't flashing. Replaced that and everything was fine until a couple days ago when it went out again. Today on my way home, the DRIVERS side went out too. Now from what I have gathered, if it was the flasher relay unit then they would have gone out at the same time and if it were the sockets then they would have gone out at different times. Also, both lenses are cracked so this leads me to think that it is the sockets and not the relay because wouldn't they have gone out at the same time? Also my DRL are out as well. So is it both sockets that are coincidentally out at the same time? If it is, should I just spend a little more money and get completely new housings and sockets for both sides?
MJE95GAGT
06-08-2006, 01:17 PM
now today my driver's side signal works again, still nothing from the passenger side :cry:
ckingcmaro
06-08-2006, 01:38 PM
I have the same problem on my maro, the way the body of the f-body's are build, and the housing of the parking light & turn signal is set up, water basically just gets blown in and it can get in the socket for the bulbs, thus blowing the bulb or causing it not to work, eventually it can melt the housing, I had to replace mine yesterday, I had an extra housing lying around fortunately, because the one in the car had been melted by the water getting in the socket. One way to help this problem is to take out the housing, and drill a few small holes on the underside of the housing so that the water can leak out, other than that, its just a design flaw....A cheap fix is to take some silicon glue and put a small bead around the outside of the housing between it and the body, if done correctly you can do this on the inside of the body so it won't go on your paint, just time and patience to do the glue. Your best bet is drilling a few holes....Goodluck bro, its an everday struggle in the rain .
DVS99TRANS
06-08-2006, 01:48 PM
Check the terminals in the sockets for any corrosion, that should be the problem. Also the next time it rains or wash your car, pull the light sockets out to see how much water is getting in there. I've replaced both of mine. Whatever you do, don't get them from a dealer. They charge like $60 for a single socket. Try autozone, pepboys,etc...
Pewterpower
06-08-2006, 06:13 PM
I don't think you have to glue your housings to the bumper. The water/moisture is coming in thru your cracked lenses. If everything is still in good shape, then try to fix the crack. Use some clear caulk on your fingertip and rub it along and into the crack on the lens. Then wipe off the excess. If the socket is still good, use some dielectric grease and get some new bulbs.
GXPPOWER
06-08-2006, 07:03 PM
hey. your bulbs arent burning out. i figured this out. i went through 4-5 diff bulbs and finally realized the problem. dont push the bulb all the way in. for some reaosn on my TA when the bulb is pushed all the way in it looses contact somehow. since then i pushed bulb into the connection mabe 80% in. and its worked perfect since. i too though mabe moisture had gotten to the bulb also. but it didnt.
MJE95GAGT
06-19-2006, 07:49 PM
Update: Well the socket is corroded so I tried to brush out the corrosion and was about to use some dielectric grease but it still didn't work so I guess it was time for me to just get a new socket. I have tried every store in town and no one carries them and can't even order them. I even looked when I was out of town and no one had it there. Am I doomed to fork the money over through GM. Anyone happen to have the part #?
pantz28
06-24-2006, 11:11 AM
I'm having the same problem with my car. Something tells me it's going to be either water or corrosion. I wash my car once or twice a week with a pretty high psi power washer. This all started a couple of months after I bought it, so I'm assuming that's it. I'll look at it tomorrow....too lazy right now, and the pool is calling me.
y2k_ta
06-24-2006, 11:46 AM
Yep, when one of my sockets went bad I ran into the same problem. No one but GM carries the socket.
GM part #12159662
BitViper
06-24-2006, 12:53 PM
time to get a set of clear lenses..
MJE95GAGT
06-24-2006, 05:18 PM
yup I ordered smoked lens covers and found the part # for the sockets in another thread and ordered it from GMPartsDirect a few days ago. $27 for the lens covers and $75 for 2 sockets.
1fastTransAm
07-01-2006, 01:54 PM
Yeah my both my turn signals went out and the housing shorted out. I have replaced a fog light due to it shorting out. Mine is going into the dealer only cause its under warrenty still and they gotta replace my D side headlight motor and the other fog light... yeah what fun.. and to get parts in Hawaii sucks
Danny2tek
07-01-2006, 07:24 PM
Is this the right part# for the DRL/lamp housing for a TA? 10301405 for left and 10301404 for right?
presto_z
07-01-2006, 07:29 PM
if they keep blowing make sure there is no debre in the socket (a peice of lastic from old bulbs..ect..) mine kept blowing and sure enough that was the problem...
