I need advice on launching.... BADLY!!
Old 06-08-2006, 01:01 PM
spacehog333's Avatar
Default I need advice on launching.... BADLY!!
The car that I am talking about is in sig. Just so that everyone is sure, it is a 6 speed. I am running 275 nitto drags on 17 inch rims with 19 psi. I went to the track last night and here is my best run. 60...2.392
330...6.105
1/8...9.063
mph...84.26
1000...11.572
1/4...13.658
mph...108.53
I did a burnout to heat the tires and on this run i dumped the clutch at 2500 rpm's. This run was my best et and 60 ft. I know the first thing that i need to do is to get my 60 ft down. Can anyone give me any tips to try next time at the track?
Old 06-08-2006, 04:20 PM
Denom's Avatar
First off i've used nitto drag radials, and find them to be lacking. They take a good 5 seconds to heat up. You'll have to do a brake stand in order to get some good heat on them. Once you do that I suggest that you launch at a higher rpm. I'm assuming you spun em, as those tires take forever to heat up. I'd say put the tire pressure down to 17 psi, and work your way down to 15 psi. See what works best for your track.
I'll be going to the track on June 17 and will make sure to post up my times for you to compare to.
Old 06-08-2006, 05:23 PM
BlueSix's Avatar
Don't dump the clutch.
Old 06-08-2006, 05:55 PM
blue01ta's Avatar
Connellsville? What track were you at, PRP?
Old 06-08-2006, 07:22 PM
Bryan @ Speed Inc.'s Avatar
when i had a similar set up i was slipping the clutch quick from 4,000 rpm. 1.8x 60' times and 12.5 e.t.'s.
it was a full weight 6spd car with a stock '99 intake and no tune on 245/50R16 nittos. =)
i'd suggest removing the front sway bar... it makes a big difference. (my 12.5 runs were with the sway bar on).
Old 06-08-2006, 10:10 PM
Thanks for the replies, I'll keep them in mind for the next time i go to the track. Yes i was racing at PRP. Where are you from?
Old 06-08-2006, 11:26 PM
blue01ta's Avatar
I'm from Washington. I'm gonna try and get up there in the next couple weekends hopefully if the rain holds out.
Old 06-09-2006, 08:07 AM
Let me know when your goin and I might be able to race with ya
Old 06-11-2006, 02:29 PM
blue01ta's Avatar
OK I will. I was hoping to go this weekend. The weather was great for racing but the track was closed for Thunder in the Burgh. So I thought about going up to that and found out they only race 330 feet. Oh well.
Quick Reply: I need advice on launching.... BADLY!!
