Mission Completed.
Mission Completed.
Finally got my car back from SQR. The final numbers are not even maxing the motor out but they are as follows;
750RWHP
1000ftlbstrq
10lbs boost
6500rpm
The staff, quality and attention to detail by SQR is in my opinion unmatched. I highly recommend them to all FI peeps, hands down if you are going SD.
750RWHP
1000ftlbstrq
10lbs boost
6500rpm
LS1Tech Sponsor
very even numbers
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Set up
6.0 iron block 408ci, patriot stg 3 heads, callies rotating assembly, ATI F1@ 10 lbs( for these dynoed numbers) 373geared strange 12 bolt, fuel tank by nasty, weldon pump, 96# low imp injectors, stock pcm. comp ratio 9.54:1
Administrator
Originally Posted by turbo'd stang
It didn't quite make that much torque....there were so many spikes, I'm guessing it was around 700-750. Fun car none the less.
FYI...I tuned it.
FYI...I tuned it.
a centrifigual would be interesting.
I've pulled the dark *** tint off my windows, got a inspection sticker, and I keep the radio turned down. I don't need to give the cops any excuse to pull me over, the damn blow-off valve makes the car sound like it's got a jet engine as it is
IS that using just teh F1 blower or an F1R?
Certainly gives me hope of making over 800rwhp with my 408/ET240cc setup with the F1C blower!
What size blower/crank pulleys are you using if you don't mind me asking!?
The crank pulley is 4 inch, the blower I haven't measured. I'm running a procharger blow-off... looks like the mondo. We're guessing mathematically we got about 300-400hp left in her.
