406 Roller motor For sale
Old 06-12-2006, 11:43 AM
CamaroFreak's Avatar
Default Two Engines for sale 350/406 Roller For sale
350 -has around 300 miles on it ,large cam 234 with a 488 lift, heads 882's, comes with carb, can hear it run
$1300.00
CHEVY 406 ROLLER
THIS SMALL BLOCK IS RACE READY; IT HAS MAYBE 25 MILES ON IT SINCE BEING BUILT in 02. IT IS A 511 BLOCK, 4 BOLTMAIN, and IT RAN A 12.53 FIRST PASS WITH NO TUNING. ARP Bolts-Double Roller Timing Gear- 5.7 Rods balanced- Moroso Oil Pan- Forged Flat-Top Pistons. Yielding 11.06:1 Compression with 64cc Heads. Over 6000.00 invested you won't be disappointed One Bad Small Block
• POLISHED VICTOR JR ALUMINUM INTAKE
• DART IRON EAGLE 200 HEADS 64CC (LITTLE TO SMALL FOR THIS ENGINE)
• COMPCAMS PRO MAGNUM ROLLER ROCKERS 1.6 & Roller LIFTERS, STUD GIRDLE
• ALL TITANIUM RETAINERS Manley Stainless Steel 2.02 Intake and 1.60 Ex Valves
• Speed pro power Forged aluminum PISTONS TRW-L2489F30
• Speed pro PISTON RINGS
Bore (in): 4.155 in.
Bore (mm): 105.537mm
Piston Material: Forged aluminum
Piston Style: Flat
Compression Distance (in): 1.420 in.
Piston Head Volume (cc): +3.40cc
Valve Relief’s: Two
Wrist Pin Style: Press fit or floating
Pin Diameter (in): 0.927 in.
Top Ring Thickness: 5/64 in.
Second Ring Thickness: 5/64 in.
Oil Ring Thickness: 3/16 in.
Notes: Approximate compression ratios: 11.84:1 with 58cc, 11.50:1 with 60.5cc, 11.06:1 with 64cc, 10.59:1 with 68cc, 10.17:1 with 72cc, and 9.78:1 with 76cc head.
Piston, Forged, Flat Top, 4.155 in. Bore, 5/64 in., 5/64 in., 3/16 in. Ring Grooves, Chevy, 400, Each
• CAM- COMPCAM (#300AR) 264-266 LIFT -630@.50
• POLISHED WATER PUMP
• HIGH TORQ STARTER
• 7-1/2 QUART OIL PAN
• MELDING HIGH VOLUM OIL Pump
• ACCEL 300+ RACING WIRES
I CAN PROVIDE ALOT OF OTHER INFORMATION, AS WELL. This Engine is running you can test drive with appt.
THIS LOCATED IN SA 3800.00
Old 06-12-2006, 12:24 PM
ex-SS-ve's Avatar
sounds like a nasty setup and a badass deal . ide pick it up as a spare if i had the room. no doubt in my mind that that motor could crack off a 10 sec slip tuned with a few changes
Old 06-12-2006, 01:43 PM
someone will get a good deal
Old 06-12-2006, 07:12 PM
pm sent
Old 06-13-2006, 12:18 PM
send your e-mail again
thanks
Old 06-15-2006, 04:12 PM
still alive
Old 06-18-2006, 03:47 PM
come on someone needs this
Old 07-05-2006, 10:56 AM
still hear
Old 07-05-2006, 07:51 PM
pm sent
Old 07-06-2006, 08:08 PM
t.t.t
