true duals before axle or after?
I been debating on either putting the true duals all the way to the tips or cutout before the axle. Which one would have a really good sound w/cats? Does it matter where it's at? Any suggestions will be useful. <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" />
Re: true duals before axle or after?
Go all the way out the back!!! If you drop off before the axle, you get a really bad drone as the exhaust is exiting right behind your seat. Just bend the pipes so they go under the axle tubes and then run out the rear like factory. Not only looks better, but even better, it won't make you an Tylonal addict <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Chris
Chris
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Judd:
<strong> Doesn't the panhard bar and panhard bar brace get in the way? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Some have removed the upper panhard bar. I simply relocated my lower panhard bar about 1" lower.
<img src="http://www.angelfire.com/on2/Vinnie/images/Painted_PHB_Bracket_1b.JPG" alt=" - " />
I did not remove anything and my exhaust is over the axle. Every now and then when I hit a decent size pot hole the exhuast will hit but other than that there are no rattles or banging. My exhaust is 2.5 with an X-pipe.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by BLASTER:
<strong> 01ragtop - How did you do that. Do you have any pictures? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I'll 2nd that
thanx for your replies. Does anybody have pictures of the true duals going all the way back?
01ragtop I would also want to see those pictures!
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by armkneez8:
<strong> thanx for your replies. Does anybody have pictures of the true duals going all the way back?
01ragtop I would also want to see those pictures! </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">http://www.angelfire.com/on2/Vinnie/truedual.html
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by CySevans:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Judd:
<img src="http://www.angelfire.com/on2/Vinnie/images/Painted_PHB_Bracket_1b.JPG" alt=" - " /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I like your idea better. When you made the new lower bracket mount, did you also lower the top mount? Reason I'm asking is because I'm wondering if the geometry is changed any. I wouldn't think dropping one side a inch would do anything, just wondering. A longer rod with a lower mount may push the axle more to the drivers side than a shorter/more horizontal bar. Have you noticed anything? Most likely it would not be enough to matter. Just curious.
<small>[ March 21, 2003, 11:44 PM: Message edited by: Judd ]</small>
