STS experts
STS experts
I want to bump up the boost. My ? is what is a safe # to be @ for a dd car?Also does it need to be retuned after. I'm at 5.5psi thinking about 7 or 8psi.
You have a front mount intercooler, 60lb injectors and a forged bottom end with 9.5/1cr, according to your signature. With your combination, you could shoot for 10 to 12 psi on the street as long as you don't see spark knock. You'll want to keep the air/fuel ratio at 11.5/1 at wot. This should get you 600 rwhp as long as your fuel system is up to the task. Bob
Originally Posted by navymitch12
but than he would need to ditch the maf or have a way to change the tune for the 2 different boost levels...becuase the car would run rich/lean depending on the boost level/tune
Ryan
