will I get the wheels up?
Heres the set up. 73 camaro.
LS1 forged bottom end, Stock heads, T-rex cam. NOS 150 shot
T56 ram powergrip HD,4:11 gears.
Trick springs with comp eng.3 way drag shocks up front, 9 way adjustable rear shocks.Custom leaf springs. Caltrac traction bars. Skinnies and 325-50-15 MT DRs.
6 point cage, weld in sub frame connectors.
The engine is moved to the rear 5.5 inches. It also has rack and pinion steering. As well as all unneed weight removed.
I dont have any power numbers yet but Im going to the track this weekend.
i dont think you'll have enought tq to do it unless you spray off the line, along with fact that you dont have drag shocks or bags (unless is missed it) or a thicker rear drag bar. i have seen stock internal ls1's barely pulling the fronts (<1") with a big stall converter, skinnies and dr's and full bolt ons so you might be able to do it, Good Luck
Originally Posted by camrsz
You think 4:11 would be too much even with the 28 inch tall tire?
What would you suggest?
How do you launch your car. RPMS ect.
Good Luck,
Daren
Originally Posted by GIZMO
The Caltrac bars are the best thing that ever happened to leaf spring cars. Did you get a recommendation from them on how to set up the rest of the car? From what I understand they really stand behind what they sell.
Good Luck,
Daren
Good Luck,
Daren
