which rod lenght
which rod lenght
on a 370" iron block?
6.100 or 6.125 with this piston....forged eagle crank, stock stroke.
http://www.flatlanderracing.com//wis...ons-sbc07.html
part number K392A3
part number K392A3
I know the stock rod length in a 346 is 6.098." If you want the stock stroke I guess you'd use the same. Don't buy anything based off my answer though.
Predator Z has a 370 and he's very knowledgeable about modding engines. He'll know.
Originally Posted by GuitsBoy
You can use either so long as the pistons are made to work with that length rod.
the piston has the option of both...I just want the piston located in the bore where it should be...Hate to order the wrong rods...
