Need Help Getting Driver's Side Header Off
Old 03-24-2003, 09:34 AM
Constrictor 98TA's Avatar
Default Need Help Getting Driver's Side Header Off
Im in the process of my heads/cam swap, and I need to get the headers off the heads. I got all 6 bolts off each side, and had a hard time getting the headers off the Y-pipe. So I took a reciprocating saw and cut the Y-pipe so they would drop. This got the passenger header out of the way, but the driver's side header is still blocking the lower 5 bolts on the head. It looks like the steering linkage (dont know of this is the right term) is in the way. I do not see any other way I get it to drop any further without getting the steering linkage disconnected.
So, does anyone have any instructions, pictures, or ideas on how I might get this done? Thanks.
<small>[ March 24, 2003, 09:37 AM: Message edited by: Constrictor 98TA ]</small>
Old 03-24-2003, 10:01 AM
Back in the staging lane
Beeler422's Avatar
Default Re: Need Help Getting Driver's Side Header Off
I took mine off to do my header install. There is one bolt holding it in. Then just shake the hell out of it to get it off.
Old 03-24-2003, 10:47 AM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Beeler311:
<strong> I took mine off to do my header install. There is one bolt holding it in. Then just shake the hell out of it to get it off. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">When looking at the steering linkage, it appears as though the linkage is made up of several different bars all connected through swivel links (sorry if Im not using the correct terms here), but at which point do I get it off? Also, is it easier to get to from the top or from underneath the car? Anyone have a pic?
Old 03-24-2003, 11:50 AM
Black Sunshine/ 00SS's Avatar
Undo the motor mounts and use a pry bar to pry the engine to the other side, this will give you the room you are looking for. You also will have to undo the tranny crossmember.
Are these SLP headers?
Old 03-24-2003, 01:01 PM
Theyre Hooker LTs. If I had a picture to show you, Im sure you'd agree the only thing in my way is the steering linkage. I think it would be more work to undo the motor mounts, and tranny crossmember and then pry my engine to the side than to undo the steering. I will crawl under there today after work and see if I can find the bolts that hold it together.
Old 03-24-2003, 03:25 PM
JRcamaroZ28's Avatar
Best I can describe it is when looking at teh front of your cart the linkage bends down towards your left foot. now on the top and bottom of the linkage there is a silver bolt(at least on mine I belive 10mm) its pretty long since it goes through the linkage. remove both of those and I used a piece of 2x4 and a rubber mallet and tapped it towards the ground and it popped right off then you can slide it around to get it off. remember the way it came off for easy install. and after that the removae should be easy. I think you also have to remove the oil diverter (above the oil flter)
JR
Old 03-24-2003, 06:57 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by JRcamaroZ28:
<strong> Best I can describe it is when looking at teh front of your cart the linkage bends down towards your left foot. now on the top and bottom of the linkage there is a silver bolt(at least on mine I belive 10mm) its pretty long since it goes through the linkage. remove both of those and I used a piece of 2x4 and a rubber mallet and tapped it towards the ground and it popped right off then you can slide it around to get it off. remember the way it came off for easy install. and after that the removae should be easy. I think you also have to remove the oil diverter (above the oil flter)
JR </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thanks for the help, but damn, is that bolt hard to get off!!!! Hopefully Im cranking on the correct one. Is the one with the green arrow the correct bolt to be trying to take off?
<img src="http://www.metalreviewcentre.com/images/Pdrm0041a.jpg" alt=" - " />
If so, then I was cranking on it with a 3/8" drive and even sprayed some Liquid Wrench on it and no go. Is there a trick to getting this off, or is it just REALLY tight?
Lastly, there is another bolt at the bottom of the steering linkage. This one was harder to get a picture of. In this picture, its partially blocked by the alternator bracket, but I drew another green arrow pointing to it. Does this bolt need to come off too?
<img src="http://www.metalreviewcentre.com/images/Pdrm0043a.jpg" alt=" - " />
Old 03-24-2003, 07:13 PM
jaywoo's Avatar
I just finished installing a set of Hookers last week on my car. Had a heck of a time with the driver's side. Kept gettting caught on the steering linkage and a little square piece of metal sticking out of the block. I didn't want to take the linkage off, so the piece of matel had to go. Ground it down with a right angle grinder, and the header popped right in. Here's a pic:
<img src="http://www.fototime.com/1308C7B16399E22/standard.jpg" alt=" - " />
Old 03-25-2003, 12:02 AM
midnightLS1's Avatar
yes, when me and justin (59apache) installed my headers yesteday we had to disconnect the steering linkage. not sure which bolt he took out, i'll ask him to take a look at your pic.
