Finally Got It!!
Finally Got It!!
Ok guys I finally got my ls1 monster running..It sounds awesome,I think its cause it still open headers but awesome!
I wanna hear your opinions on what itll run..
Its a 2002 TA lotsa weight reduction Im not sure what it weighs but I hope under 3100 with me in it..Th400 4500 8" coan converter, 12 bolt 4.10 gear,26x10x15 hoosier drags, mickey et fronts in the front,alston lca,alston T/A,Alston PH,Alston SFC's, QA1's up front with QA1 Springs, hooker headers,full aeromotive fuel system,custom ground cam .651 .654 .250 .254@50 on a 108 lsa...diamond pistons, arp rod bolts,lotsa porting on the stock o2 heads,ls6 intake....
any guesses,im hopin to see at least a high 10 out of it but who knows anythings possible...
no dyno yet but probably next week sometime...PCMforless tuned it to the specs of the motor and I must say for a mail order tune it runs really good,its not really rich or really lean no hesitation runs great...
Hopefully going to make some shake down runs tonite ill post up tonite when I get back...
This set-up needs more than a mail order tune. Hard to say. Sure you have a big cam, loose stall and short gears but if they do not work well together than forget it. Easy 11s though. If it works well together than 10s are there.
Well went to the track last night and came home very dissappointed,but woke up this morning feeling not too bad..
Track was great DA wasnt too bad,first pass just baby'n down the track makin sure she wasnt gunna come apart it went 13.80@101 short shiftin and not launchin..
2nd pass 13.08?!@104?! WTF and I shifted about 6500 and launched about 3800...hmm
3rd pass,battery dies 1000 ft out,alternator was NOT working all day now I dunno how bad that is but I just got it hooked up and seems to run about 20 times better..So Sunday we will have a go at it again...
Good Luck on sunday. I know how shakedowns can be. I made one last week and only ran 12.12 @ 118.49 with a 2.001 60'. Track prep sucked and I got rained out. Also still learning the new set-up from a driving perspective. Hope to try again next tuesday.
