running cold
Old 06-16-2006, 09:37 PM
redhot lt-1's Avatar
Default running cold
the other day i replaced my plug and broke the coolant sensor on the drier side head easy to replace but now my car is running rich and cold causing the car to skip under load temp barely comes off 160 any ideas what the problem is i think the new sensor is it but i want some other opinions your help will be greatly appricated
Old 06-16-2006, 09:51 PM
harvickgm's Avatar
how do you know its only coming up to 160??? are you going off a datalog or just reading the temp gauge. the 1/4 line on the gauge is actually like 190 deg.. alot of people get confused by that.. but as for the skipping did you only replace one plug???
Old 06-16-2006, 10:31 PM
Honda Hunter's Avatar
The only purpose of the sensor on the head is for the temp gauge in the dash and nothing else. It doesnt change the way the car runs. Get the temp using from the computer using freescan, datamaster, or something along those lines.
Old 06-16-2006, 11:25 PM
harvickgm, its barely getting off the 160 mark and it was hot today i`m wondering if it is giving the computer a faults read and keeping the auto choke on allowing it to run rich
Old 06-16-2006, 11:31 PM
Did you read what I posted? Theres a 10-15 degree diff between the two sensors.
Old 06-17-2006, 01:56 PM
harvickgm's Avatar
but did you only replace that one plug... and also how are you getting that temp? are you just reading your temp gauge or are you datalogging it??
Old 06-17-2006, 07:20 PM
i think we`ve found the problem i put it on a computor of a friend (he has the keys to the local gm dealership) found 4 codes 1, p0122 pedal position sensor (my car doesn`t carry this sensor it`s in 98 and up) 2,p0135 02 sensor heater circuit malffunction,3, p0336 crankshaft position sensor,4,p0400 egr valve. i fix the egr valve broken vaccum line i`m waiting on the other parts i hope this fixes it
Old 06-17-2006, 07:23 PM
harvickgm's Avatar
thats why i was saying that you need to datalog the car to know whats going on.. did you test the O2's or are you just going to replace them??
Old 06-17-2006, 07:33 PM
the o2s are ok the code says its an wire issue i just had a set of pacesetter headers put in and they rewired the o2`s and the wire may have burnt or come lose but i`ll know more monday
Old 06-17-2006, 07:35 PM
harvickgm's Avatar
i had to do the heated 02 conversion to mine... the wiring is not that hard...
Old 06-17-2006, 08:50 PM
how is that done i may need to do mine
Old 06-17-2006, 08:52 PM
harvickgm's Avatar
what year is your car???
Old 06-17-2006, 09:08 PM
96 t-a
Old 06-17-2006, 09:18 PM
harvickgm's Avatar
oh, yours already has heated O2's on it. so no need for that.. just check and make sure that there is not corrosion in the connectors. and that all connections are good..
Old 06-17-2006, 09:32 PM
thanks man i`ll have the machance that installed my headers check it
Quick Reply: running cold
