Need to know asap: injectors
they basically support the mods you're doing. You're not going to gain anything from larger injectors unless you're maxing out the duty cycle on the ones you have..
Typically a 30lb injector will handle H/C cars..
A larger injector won't add any horsepower. Just support more power. 50# is kind of overkill for H/C, the highest I would go is 42# and even that's high for the setup.
