Cam selection
Cam selection
I am looking to get 400rwh with the install of a cam that would be suitable for street/strip use after it is tuned. I would also like a nice choppy idle after install too. The mods that I currently have that make power are: Pacesetter lt's, TSP ory, SLP Loudmouth catback, Whisper lid. What kind of cam should I be looking at to go with stock heads for now? With the cam, I would also be getting springs, pushrods, timing chain. I have been looking at all of teh posts about cams, but I am stii undecided at which one to go with. Any suggestions woudl be appreciated.
Nick
Nick
TSP torquer2 232/234 duration 595/598 lift on a 112 will net you over 400rwhp and one hell of a lopey car. After tuning the drivability will not be an issue especially if you have a 6spd. a 224/228 on a 114 would not have much of a lope to it at all, the cam is way too small.
Originally Posted by 2002ssls1
Will a 114 lobe seperation be noticable at idle?
When you get 400+ HP, people will take notice, no matter how smooth it idles.
yeah i may not be at 400 HP with my cam but do your self a favor and talk to a mathematician about why tq is used to derive hp, you want tq not hp
"On modern day dynamometers horsepower is a calculated value. It's important to remember the dyno measures torque and rpm and then from these calculates horsepower"
Nick
Nick
Originally Posted by 66deuce
if you wanted TQ,why did you go with a 114 lsa?a 224 on a 110-111lsa would produce killer TQ down low.
do you have a stick or A4?what gears /stall are you running?400hp is cool,but you need to match your cam to the rest of your combo to get the best out of it.you'll want something in the 230+ dur. to net you over 400 hp with stock heads.you will lose drivability in the lower rpm range,but if you can deal with that then go for it.
if you wanted TQ,why did you go with a 114 lsa?a 224 on a 110-111lsa would produce killer TQ down low.and bigger cams still make TQ,just at a higher rpm.but i agree you want a broad power band,or HP under the curve for a street/strip car.
emissions i have cats that go on for the sniffer
Can this cam be used with stock heads?
