Will these rods work?
http://cgi.ebay.com/ebaymotors/Eagle...spagenameZWDVW
the reason i ask here is because this section has alot of knowledge. the pistons use .927 steel tool pins and it's a stock crank. yes i know it's a 6.250 rod. just need to know everything mates up.
Originally Posted by 67Firebird455
Shoot man, wish I could help you out, I have NO idea when it comes to Ford stuff... =( TTT for ya, good luck with your project!
Although im probably needing a math refresh on these formulas, wont that leave you an 1/8th" to tall for the deck height? Wouldnt the compression height need to be like 1.169 on stock stroke?
my compression hight is 1.103. I was going to run a 6.3 rod but I needed to lower my compression a little bit because of the dome pistons. and it should be in the hole. with a 6.250 rod can anyone check the math for me please.
