2.1 STR too low?
Old 06-29-2006, 03:52 PM
LS1 Eddie's Avatar
Default 2.1 STR too low?
I ordered a Yank SS3200 that I'm assuming is coming with a 2.1STR like it says on the website. I'm going to be using the 3:23s for a little while. I don't want the car to be mushy around town. Could somebody tell me what this should be like?
Old 06-29-2006, 08:20 PM
Moderator
jimmyblue's Avatar
This I think will be an ideal "street" converter. You will
get used to the higher RPM fairly quickly, this converter
will still have some coupling at lower RPM (should cruise
fine at 1500 on the level). LT1 probably wants to stay
with this sort of RPM unless very modded for top end.
2.1 STR is sensible, not a super hard hit to the tires but
still a gain over stock and leaving you with a broader
torque multiplication, not such a sharp and fast-fading
peak. Enjoy.
You may feel "mushy" at first but discover that this is
really letting the engine slide into powerband at will,
under pedal control.
Old 06-30-2006, 11:00 AM
Fast GTO's Avatar
You will notice it being a little mushy but the performance gain is from being in the powerband more often.
Old 06-30-2006, 11:49 AM
silverado01's Avatar
my 2.0 str isnt too mushy
Old 06-30-2006, 10:21 PM
C5XTASY's Avatar
peak. Enjoy.
This is absolutely right. I have a heads, cam, longtubes, etc., C5 and am running a Yank SS3200. It makes for a fantastic daily driver and high performance street machine. The car still pulls at idle and, at partial throttle, feels like a stock converter. My only problem, if you can call it that, is that I have to learn a new technique to launch it without frying the tires. A slow roll into the throttle seems to work best, but is kind of hard to do. I keep wanting to floor it. You will love this converter. By the way, I have 3.15 gears.
Ed
Old 07-01-2006, 05:47 PM
LS1 Eddie's Avatar
Thanks for the help guys. It's going to be here wednesday, I'm looking foward to it.
