running like crap after LT install?
So i finally put my pacesetter longtube headers on. After a day of putting the bitches in, i take it to a muffler shop with open headers. I didn't notice anything because i was driving under 1500rpm with a feather on the gas. After i get everything welded on, 02 sensors put in. I take off, and notice my temperature guage not working at all. Also, there is a lot of hesitation and backfire. I did not put the EGRs on, nor the other one, AIR i believe? the ones on the passenger side have block of plates, but i left the driver side open.(i will fix that when i find that damn piece). I also wonder if it could be my spark plugs because i took them off to get clearance for the driver side and they may have gotten dirty? im going to overcheck everything tomorrow. But i was wondering if there is anything else i am overlooking. Any help would be helpfull.
Thanks
-Saad
Thanks
-Saad
Thanks
-Saad
Thanks
-Saad
Make sure you didn't crack one of your spark plugs putting it back in. One little crack in the porcelain and it will misfire like a motherfxxxer. Also make sure all the spark plug wires are plugged all the way in.
Thanks
-Saad
Thanks
-Saad
i took my plugs and coil packs off..a lot easier that way. i have triple checked my wires and plugs even heard the click on both ends. I am changing my plugs this weekend upgrading to the iridiums instead of copper. then might need a retune. I am gonna also check 02's cause they do have like 76K on them.
thanks for all the input guys. i looked everything over, and im pretty sure some of the plugs are gone, also, i am going to put the block off plate back on today, and see what happens. can i run without EGR or AIR?
You need to get your water temp working as well. Computer needs this for correct tunning. Make sure exhaust system is sealed tight prior to the 1st 02,s and cats.
As for your air-egr you will need to get a re tune. Not only delete SES-fault codes. There will be some cold startup issues with the missing air. And of course to tune for the LT,s installation as well.
I was going to suggest changing the plugs, but it looks like you are doing that already. Check the temp. sender in the driver' s side head to make sure the wire isn' t damaged or disconnected.
Good luck. I' m sure you' ll be okay.
GET A TUNE!!!
GET A TUNE!!!
If your temp guage is not working that is a signa that something is wrong with your sender of wiring. This reading is CRITICAL to vehicle performance. Check your connection and sensor. Ive got $50bux, that says this is your problem.
yeah, running back through it, i noticed the temperature sensor was unplugged (DOH!), so i put that back on, one of the plugs next to the dipstick was lose, fixed that, and i just sent the car to a shop to bend the EGR tubes the right way to fit. Hopefully it will be alright
Thanks for all the input, i appreciate it.
-Saad
-Saad
Hope the shop can fix some of your problems, I thought it was pretty much mandatory to have a good tune after a LT install, that could be your problem unless I missed you having it tuned already somewhere.
Maybe it's different on the LS1's, but I know with LT1's almost everyone gets a tune... might wanna wait for a couple more answers before buying one, but I think you can get them from 150-250 range mail order... check the sponsors :-).
