Vertical Scratch in 2 cylinders, why?
So basically it wasn't built right, if you know nothing got into the engine.
Would this happen over time or right away?
Car got tuned on a dyno when it had over 500-600 miles on it and made great power, 3,000+ miles later, power seemed/felt down. Did a compression check and leak down, found that 2 cylinders were way low. Pulled heads off and found a scratch that you can feel in the cylinders that had low compression and leak down on those same cylinders.
when i put my second set of heads on my car,noticed verticle scratches in two cylinder walls.stock block.i know i got some dirt in there from the first H/C install,even tho i thought i did a good job of cleaning everything.and those two cylinders have the lowest compression
for the first 5-600 miles did the car run very rich? too much gas in the cylinders can wash the oil off the cylinders and eat your rings/cylinders fast. but i dont know about one single scratch....
