Dyno vid of my ttvette
I'm out here in good o'l Tucson AZ
Motor is 408 stroker 8.5:1 comrpession built by larry's engine and marine
Turbo kit is hp eprformance twin 57mm installed and tuned by them, fuel system from them too.
110 degrees of ambient air in dyno shop netted the following numbers.
Little bit of tire spin on dyno
That thing sounded badasp on the rollers plus very nice numbers at 8psi in the 110degree heat. I bet you got a whole lot more in it w/ more boost(obviously) & less spin on the rollers!!! What cam & injectors/fuel system you running??? Was the A/F looking ok???
Ditto to what 67Firebird455 said below as well!!!
60lb/hr injectors motron i think.
Originally Posted by kindaslo
comp cams 236/242 .600 lift ish i think... Can't remember honestly.
Anyway, good luck with that wicked vette and be safe!!!!
