Pics of my Aerospace lightweight Brake conversion
Turned out pretty nice. I have heard many people say good things about the Aerospace kit and heard a few bad things. I thought I would give it a try and see for myself. Took me a couple of hours for the install. I must say I like it.
Gotta be about 40lbs...... If you pick up a stock rotor and caliper assembly it weighs a frikkin ton....
Glad to see you finally got em in and on there.... how was chopping the ears off the steering knuckle? not too bad huh???? they look great....
Thanks man.
tony, could you post a pic of where you grinded on the ear?
also this setup doesnt come with a dust cap? hate that rusty (though you painted) oem part showing with that pretty brake setup. i am going with the same setup. from what i hear its a 30 lbs difference. the strange is 50 lb less due to the aftermarket spindle area.
Originally Posted by Tony Shepherd
I will try to get a pic for you. The center cap also covers that up so you cant see the stock hub.
any reason you didnt put the center cap on it?
i appreciate the pics.
yea that is it. i was hoping to see it with the center cap. stock hub is ugly! lol
Here is a pic of the ears you have to grind off and smooth down the knuckle.
I have those Tony and am happy for the most part. Make sure you check the bolts that hold the calipers together. Mine lossened up and allowed all the brake fluid to push out between the halves. Luckily it happened as I was setting the line lock for the burnout rather than at the other end as the pedal dropped right to the floor. Other than that, I like mine.
