Building a TT setup with stock manifolds
i bet its been asked before but i did some searching and even went back several pages but found nothing. can you run stock fbody manifolds in their stock location with a pair of small turbos mounted Incon style? maybe do a little clearencing on the body and run a small starter like Speed INC is on their new tt setup they are building? i dont see why something like this wouldnt work unless maybe the manifold is too long and pushes the turbo down to far? but thats all i can think of..ideas?
Try it and let us know how it works out. A ton of the Turbo set ups in here were done by trial and error.
The 408 front mount set up I an doing is just going to be a copy of a few poeples I have seen in here.
Restricted User
I asked Jim the same question after looking at his new TT Setup. Seems there would be room, if not the F Body Mani's then maybe some other kind, but just looks like something would fit in there.
Originally Posted by CAT3
Just read Jim's reply in his TT setup thread. There is a drainback issue with trying to use Stock Manifolds, which explains why dozens before havent gone that route.
theres the idea of building a PTK style kit using a truck manifold and an fbody manifold, but i was reading that PTK kits have a problem with ground clearence. is there anything thats been done about that?
