SCR DCR calculator?
Old 07-10-2006, 10:34 AM
viewsonic's Avatar
Default Help me calculate SCR
Bore Size: 4.000
Piston Stroke Length: 3.622
Piston Dome Volume: 0
Piston Deck Clearance" -.007
(Those should be the numbers for a stock ls2 bottom end. Correct me if I am wrong.)
Combustion Chamber Volume In CCs: 58
Head Gasket Bore Diameter: 4.030
Compressed Head Gasket Thickness: 0.045
What is the SCR?
Old 07-10-2006, 10:41 AM
ChevPower's Avatar
12.33 is what i came up with
Old 07-10-2006, 11:05 AM
PREDATOR-Z's Avatar
Yeah aproximately 12.33 (actualy a little less)
Old 07-10-2006, 11:15 AM
viewsonic's Avatar
Sweet thanks guys!
Thats the number I got too... Just making sure I was doing it right.
Now I need to get my cam card so I can figure out what the DCR will be exactly.
Old 07-10-2006, 05:36 PM
viewsonic's Avatar
Default SCR DCR calculator?
Anyone know where I can get one?
I googled... but only found ones you have to pay for...
Old 07-10-2006, 05:43 PM
jrp
SN95 Director
jrp's Avatar
https://ls1tech.com/forums/advanced-engineering-tech/394937-updated-valve-event-dcr-scr-header-length-spreadsheet.html
Old 07-10-2006, 05:50 PM
exSSer's Avatar
This is the one I used because I don't have Excell.
http://www.kb-silvolite.com/calc.php?action=comp[URL=http://]
Old 07-10-2006, 06:25 PM
viewsonic's Avatar
Hmm I am doing somin worng...
I am getting the correct SCR (12.3) but the DCR is messed up. (I am getting like a 10.4 DCR... I have never calculated DCR before... so this is probably why I am off.)
Cylinder Head Volume (cc) 58
Piston Head Volume (cc) 0
Gasket Thickness (in.) .045
Gasket Bore (in.) 4.030
Cylinder Bore Diameter (in.) 4.000
Deck Clearance (in.) -.007
Rod Length (in.) 6.098 (Thats a guess?)
Cam info:
-------------------------------Intake-----Exhaust
Valve adjustment:--------------.000"------.000"
Lobe Lift:----------------------.370"------.370"
Gross valve lift 1.70 ratio:-------.629"-----.629"
Duration @ .050" tappet Lift:----243*------247*
Lobe seperation 112*
reccommended Intake cernterline 108*
specs at 108* intake centerline:
Valve timing at--------------------Open-------------------Close
.050" tappet Lift:----------Intake: 13.5* BTDC------------49.5 ABDC
--------------------------Exhaust: 59.5* BBDC-----------7.5* ATDC
.050" tappet Lift:----------Intake: 11.5* BTDC------------51.5 ABDC
--------------------------Exhaust: 57.5* BBDC-----------9.5* ATDC
Old 07-10-2006, 06:34 PM
SuperSporttruck's Avatar
what is this motor ? A stock 6.0L ? And you need the duration at .006
Old 07-10-2006, 06:35 PM
viewsonic's Avatar
Yup.
Stock bottom end LS2
Old 07-10-2006, 06:36 PM
jrp
SN95 Director
jrp's Avatar
you've got to use seat timing not .050"
Old 07-10-2006, 06:39 PM
viewsonic's Avatar
How do I do this?
The info above is the only info I got.
Old 07-10-2006, 06:44 PM
jrp
SN95 Director
jrp's Avatar
what lobes are these? does the cam card state .006*?
Old 07-10-2006, 06:47 PM
viewsonic's Avatar
Cam card does not state .006*
Old 07-10-2006, 06:52 PM
viewsonic's Avatar
I bought everything from flowtech, (pushrods, heads, cam) so Ed was able to callculate my DCR... I just wanted to be able to do it myslef.
Anywho.
This is what he told me:
12.3:1 SCR
8.75:1 DCR
This will be run on 93 octane. Wathca think?
Old 07-10-2006, 06:59 PM
jrp
SN95 Director
jrp's Avatar
hmm, my FTI cam card had .006 and .050* duration. ask Ed for the seat timing if you'd like to calculate DCR yourself. he uses the whole comp catalog at his disposal so there's no telling what lobes he used.
my SCR was 12.03 and DCR 8.5 to be run on 91 oct. but the combo never saw the light.
Old 07-10-2006, 07:28 PM
slowride's Avatar
Comp has all the cam grinds listed in a pdf file if you look on the website. They tell the .006" timing in deg. If you know what style it is (xe, xer, etc) or the grind # you can figure it out.
Edit my bad the Comp website doesn't ofer the .006" numbers. I used J-rods spreadsheet to figure out the .006" numbers.
Old 07-10-2006, 07:52 PM
viewsonic's Avatar
This help?
Old 07-10-2006, 08:06 PM
MSGHUFF's Avatar
This sheet has the lobe data : DCR Calc
Old 07-10-2006, 10:28 PM
pianoprodigy's Avatar
Yep, my calculator will lookup the lobes provided you enter the proper duration and lift as it is listed in Comp's catalog. Look at the tab titled lobe source if you can't get it to lookup the values properly.
Quick Reply: SCR DCR calculator?
