What's a good A/R combination?
hey i'll be shopping for a turbo soon but i wanna know wat AR combination is everyone running.im looking at t70's. more then enough,but wat AR should i pick?the car is a 98 ss all stock with an automatic tranny and it will be a daily driver.i want around 500rwhp and nice strong powerband all the way through 6500 rpms
Originally Posted by ls1king000
What a/r for twins? Innovative or gt40s
stock motor now
later 370, 6.0 heads
3.10 or 3.20 gear
stock motor now
3.10 or 3.20 gear
Originally Posted by MiaSSmaro98
.96 on the exhaust turbine correct?wat about the front?
the compressor a/r is not as versatile as the turbine a/r. Basically, since the compressor side doesn't really change much in turbo dynamics, the turbo manufactures will leave it at a set "baseline".
However, the turbine a/r is where the magic is at and where the a/r talk is guided at.
The higher the ratio, the more peak power you will attain while compromising a bit of turbo response. The lower, well, you get the opposite....
Now, ppl are running a .96 single setup. On a twin, theoretically, you should expect that turbo to spool slower, corrrect? So, with a 408 twin setup, should you consider running a lower a/r (let say on a t70-t76) or stick with it .96 since the motor is also pushing alot more air per bank?
I would like to match a pair of super-t's t70's or t-72's .96a/r.
i had the .96 and i could not stand it - big lag but it made good power on top end. i switched to a .81 and it is much more fun , quicker boost just great on my auto trans daily driver car. .81
twin t-64s ceramic bearing
350 cubes
.81 A/R turbines(on center housings)
starts boosting around 3300rpm pulls hard to 7000
works good on the street. backpressure matches boost
350 cubes
Originally Posted by nitrorocket
.96 is WAY too big for a twin setup, Use .68 housings. Also, t70 is way too klarge for only 500 rwhp. Use 60-1 hi-fi's or similar.
Really?? I'm running twin 67's with .96 A/R. Boost comes in at about 3500, carries to red line (what ever I want, right now 6800, but easily could be 7200). No problems what so ever on getting boost. NO LAG. Launch off trans-brake is fun again. My HP and times are in my signature.
David
