installing headers and want to get cam
Im getting headers and a y pipe with hi flow cats and get the car dyno tuned i was considerign geting a cam at the same ime what would be a good cam to go with my car is a DD, what would be a good choice for a cam
The 224 is mild, but look at his mods. I'm all about big cams as the 2 camaros at my house have big cams, one a Trex and the other an Ms4, but you need to have supporting mods for all that, and he doesn't even have a stall yet.
228 is the most I would go for that car.
Originally Posted by 01BlackCamaroSS
who makes thease cams? i was looking at the lunati voodoo cams for the ls1 r they any good
kool thanks for the help, will the ms3 be good with the stock converter or will i have to change the torqu converter
Here is what I would get if I were you:
-Big stall
-MS3 or MS4 + spring kit + pushrods
http://www.texas-speed.com/shop/item...d=175&catid=49
-LS6 intake
-Gears (optional)
This stuff will not cost you a fortune, and you will make some great power!
P.S Here is my cam: 243*-247*-112*-.629"-.629"
Granted it is in a 364 (ls2) and I have a M6. I also have every supporting omd there is
-Big stall
-LS6 intake
-Gears (optional)
Originally Posted by monicaz28
That is the difference between your car and his car, and why I made a mild cam recommendation for his car.
I dunno... I just like big cams
Originally Posted by viewsonic
your reccomendation is a good one.. But I was just saying that cam is the way to "play it safe"
I know what you're saying though, it's just hard to justify putting an Ms3 on a stock intake and converter. Now with all the right goodies, the Ms3 is my second favorite cam (soon to be 3rd hopefully when I find out what kind of numbers my Ms4 is putting out) and one of the greatest nitrous cams IMO. It takes money to get you where you need to be for a big cam, but then, you gotta pay to play.
224/228...with a good tune you'd hardly know you had a cam unless you have timeslips to compare at hand.
if you plan on going over 220 with the dur, i'd suggest an aftermarket torque converter. for the cam duration i suggested, i think 3,400 stall speed would be the lowest you could go without making your car a dog off the line.
